Using the esc screen is a synthetic test. Does the strafe issue still exist?
There are multiple reasons this doesn't help:
strafing is constant input, not 1 time
the esc screen instantly jumps to 999 fps, which does not happen when strafing
Is this input lag? (Video)
Re: Is this input lag? (Video)
2023 Esports Guide: forums.blurbusters.com/viewtopic.php?t=11799
Windows 10 Esports Guide: forums.blurbusters.com/viewtopic.php?t=10724
It's not so much synthetic, as it is a baseline to rule out other factors; if his keyboard has normal responsiveness to an instantaneous transition in a game, then whatever transition is slower in the same game is likely in-built delay.
Different animations usually have different levels of artificial responsiveness and delay. I've experienced this in multiple games in my high speed and LDAT testing.
For instance, measuring a slower looking melee weapon animation in Overwatch will produce much higher average latency readings than a weapon with a faster looking animation because the former simply purposely takes longer to react to user input (to create the illusion of momentum and weight, etc).
He'd need to perform high speed camera, Reflex (built into some native G-SYNC monitors), or LDAT tests to confirm anything further.
Nice informationjorimt wrote: ↑15 Mar 2023, 17:41It's not so much synthetic, as it is a baseline to rule out other factors; if his keyboard has normal responsiveness to an instantaneous transition in a game, then whatever transition is slower in the same game is likely in-built delay.
It's not constant input. When you press a key, that's a key down event. If you hold the key, nothing happens. No events. When you release the key, you get a key up event.
Jumping to 999FPS shouldn't matter. You're trying to test keyboard latency, not game rendering latency.
Writing a simple tool to check keyboard latency is very easy. I whipped one up in 2 minutes in C++ and SDL2:
Code: Select all
#include <SDL2/SDL.h>
int main(int argc, char* args[])
if (SDL_Init(SDL_INIT_VIDEO) != 0) {
return 1;
SDL_DisplayMode info{};
if (SDL_GetCurrentDisplayMode(0, &info) != 0) {
SDL_Quit();
return 2;
auto* window = SDL_CreateWindow(
"Keyboard Latency Test",
SDL_WINDOWPOS_UNDEFINED,
info.w, info.h,
SDL_WINDOW_OPENGL | SDL_WINDOW_FULLSCREEN | SDL_WINDOW_INPUT_GRABBED | SDL_WINDOW_ALLOW_HIGHDPI);
auto* renderer = SDL_CreateRenderer(window, -1, SDL_RENDERER_ACCELERATED | SDL_RENDERER_PRESENTVSYNC);
SDL_GL_SetSwapInterval(0);
SDL_SetRenderDrawColor(renderer, 0, 0, 0, 255);
SDL_Event e{};
bool flip = true;
for (;;) {
while (SDL_PollEvent(&e) != 0) {
if (e.type == SDL_QUIT) {
SDL_DestroyRenderer(renderer);
SDL_DestroyWindow(window);
SDL_Quit();
return 0;
} else if (e.type == SDL_KEYDOWN && !e.key.repeat) {
if (flip) {
SDL_SetRenderDrawColor(renderer, 255, 255, 255, 255);
} else {
flip = !flip;
SDL_RenderClear(renderer);
SDL_RenderPresent(renderer);
For things like that you should get baseline recording of perfect looking animation at same fps and then do another recording for suspected wrong looking animation overlaying with transparency too see if there is any discrepancy. Would be perfect if it was external cam recording with 1000fps. All synced with start of movement by turning of led that would also be recorded.
Of course it would have to be animation that is consistent in game.
Ryzen 7950X3D / MSI GeForce RTX 4090 Gaming X Trio / ASUS TUF GAMING X670E-PLUS / 2x16GB DDR5@6000 G.Skill Trident Z5 RGB / ASUS ROG SWIFT PG279QM / Logitech G PRO X SUPERLIGHT / SkyPAD Glass 3.0 / Wooting 60HE / DT 700 PRO X || EMI Input lag issue survivor
Lol and that one youtube video saying that changing keyboard repeat delay to short will fix input lagRealNC wrote: ↑16 Mar 2023, 05:21It's not constant input. When you press a key, that's a key down event. If you hold the key, nothing happens. No events. When you release the key, you get a key up event.
Compiled executable is attached. Simply press any keyboard key to flip the screen between black and white.Code: Select all
#include <SDL2/SDL.h> int main(int argc, char* args[]) { if (SDL_Init(SDL_INIT_VIDEO) != 0) { return 1; } SDL_DisplayMode info{}; if (SDL_GetCurrentDisplayMode(0, &info) != 0) { SDL_Quit(); return 2; } auto* window = SDL_CreateWindow( "Keyboard Latency Test", SDL_WINDOWPOS_UNDEFINED, SDL_WINDOWPOS_UNDEFINED, info.w, info.h, SDL_WINDOW_OPENGL | SDL_WINDOW_FULLSCREEN | SDL_WINDOW_INPUT_GRABBED | SDL_WINDOW_ALLOW_HIGHDPI); auto* renderer = SDL_CreateRenderer(window, -1, SDL_RENDERER_ACCELERATED | SDL_RENDERER_PRESENTVSYNC); SDL_GL_SetSwapInterval(0); SDL_SetRenderDrawColor(renderer, 0, 0, 0, 255); SDL_Event e{}; bool flip = true; for (;;) { while (SDL_PollEvent(&e) != 0) { if (e.type == SDL_QUIT) { SDL_DestroyRenderer(renderer); SDL_DestroyWindow(window); SDL_Quit(); return 0; } else if (e.type == SDL_KEYDOWN && !e.key.repeat) { if (flip) { SDL_SetRenderDrawColor(renderer, 255, 255, 255, 255); } else { SDL_SetRenderDrawColor(renderer, 0, 0, 0, 255); } flip = !flip; } } SDL_RenderClear(renderer); SDL_RenderPresent(renderer); } }
keyb_lat.zip
