2023 Esports Optimization Guide
Re: 2023 Esports Optimization Guide
what you do with WUshowhide app? you just hide all updates from microsoft?
No!! I just hide drivers.
okey but how you use monitor's audio which have Microsoft driver ,as i see know on my pc its using nvidia driver
You need to exclude the HD audio driver from the Nvidia driver installation.
I can exclude HD audio driver when i install driver for nvidia gpu with NVCleanstall? And i understand that you dont update driver for your ethernet thats right?
Hey, I also have a Realtek GBE NIC and I'd like to try this.
Could you tell me the name of the Windows legacy driver that you're using?
There are a lot of options to choose from the device manager list, but I'm not sure which one should I use.
At the moment, with the Realtek driver, my NIC's device service is RTL8167.
Just uninstall the nic device with package removal from device manager and reboot. After, Windows will install correct drivers.andreeeeee- wrote: ↑04 Jun 2023, 04:12Hey, I also have a Realtek GBE NIC and I'd like to try this.
I' don't keep old drivers, I use what Windows installs with a clean installation.andreeeeee- wrote: ↑04 Jun 2023, 04:12Hey, I also have a Realtek GBE NIC and I'd like to try this.
I have W10 22H2 and the ethernet driver version is 9.1.410.2015 and the date 10/04/2015.
Actually you don't need NVCleanstall, you can just select the graphics driver with Nvidia package and exclude the HD audio and also what InputLagger said but to be fair I never tried Nvidia HD audio driver so it can be fine. If you want to be sure use Xperf from Microsoft and test it.
And yes, ethernet I use Windows default driver.
