Problem with Windows 10
kHAZY
Post by kHAZY » 23 Mar 2023, 08:01
This might be a weird one for you guys but i try to recreate the windows 7 mouse feeling that was the best aim ive had it was kinda a heavy aim but it was very precise and i could still move my mouse freely. Now if i lower my sens its just too slow and unprecise.
On windows 10 its kinda like that 800 DPI is much faster now and everything seems way too "snappy and fast" so i tried out to use Rawaccel on the Setting "Off" with a negative sens multiplier like 0.5 and 250 hz mouse polling rate and it was almost great for me but something is bugging me using it its just not the same do you guys know if theres something else i can do to recreate this kind of "heavy" aim? I had this without Acceleration
Stimpy7314
Re: Problem with Windows 10
Post by Stimpy7314 » 23 Mar 2023, 08:08
Yeah, just tape a stone brick on your mouse. Problem solved.
Vocaleyes
Post by Vocaleyes » 23 Mar 2023, 08:40
I agree completely with windows sensitivity being off, how some people are running 6/11 1600dpi is baffling to me as even 6/11 400dpi feels way too fast.
Stimpy7314
Post by Stimpy7314 » 23 Mar 2023, 09:27
Vocaleyes wrote:
23 Mar 2023, 08:40
https://youtu.be/Sbzs5IFCoMQ
imprecise
Post by imprecise » 24 Mar 2023, 04:04
kHAZY wrote:
23 Mar 2023, 08:01
I think this is likely caused by dwm.exe being set to High priority, interfering with the responsiveness of inputs. In my experience, lower hz mice are less affected by this issue. You can test setting dwm to below normal from task manager > details and see if you notice a difference.
viewtopic.php?t=4512
Stimpy7314 wrote:
23 Mar 2023, 09:27
Vocaleyes wrote:
23 Mar 2023, 08:40
Great video! Screen resolution is another factor here. High resolution low DPI causes a very low sensitivity.
