Hardware accelerated gpu scheduling on windows server
Avallac
Post by Avallac » 23 Mar 2023, 20:28
Followed the suggestion on here to use windows server instead of regular windows for better latency/frametime consistency and such. Installed windows server 2019 and its been working fine after manually editing some intel Ethernet drivers to make them work. Unfortunately there is no option for hardware gpu scheduling and things like DLSS frame generation don't work because of it. Does anyone know any way of enabling hw scheduling on windows server? Is there even much benefit latency wise to using server when you can't even use hardware scheduling on it?
deama
Re: Hardware accelerated gpu scheduling on windows server
Post by deama » 01 Apr 2023, 17:01
I think the guys were just speculating on better latency with the windows server, unless you're planning on playing a specific competitive game, it's not really worth it.
I think the only improvement with windows server is the lack of bloatware, that's about it innit?
Mugabi
Post by Mugabi » 01 Apr 2023, 17:33
deama wrote:
01 Apr 2023, 17:01
That and the ability to completely disable updates . In normal windows, you can’t really disable update, it will download stuff in the background whether u like it or not lol
timecard
Post by timecard » 01 Apr 2023, 22:37
You could just "delete" the related windows update services/scheduled tasks.
