Useless tweaks.
texre
Useless tweaks.
Post by texre » 25 Mar 2023, 20:48
Doing all those tweaks literally do nothing. Ask any pro in any game 70% of them just buy a pc download their game and play with zero issues. Doing tweaks is pointless doesn’t help at all.
Ferr0
Re: Useless tweaks.
Post by Ferr0 » 25 Mar 2023, 21:50
Plenty of pros turn off hyperthreading for csgo. Even shroud mentioned turning it off because he said he got more fps with it off. Turning off hyperthreading alone is pretty great.
SKILLEN
Re: Useless tweaks.
Post by SKILLEN » 26 Mar 2023, 00:41
Probably there are minimal benefits from tweaks, if you dont have input lag problems,but yes, if you have input lag,tweaks wont help.
FPSMaster
Re: Useless tweaks.
Post by FPSMaster » 26 Mar 2023, 10:02
texre wrote:
25 Mar 2023, 20:48
Always important to know which tweaks you mean... there are tweaks that indeed help with FPS.
For example Disabling Memory Compression, Disable HPET, Debloat Windows for lower CPU Usage etc. These are Tweaks that boost 0.1% low and 1% low FPS and decrease Stutters. There are also many tests that proof this.
Very effective tweaks like Limiting FPS, OC CPU/GPU etc which will massively decrease Latency.
Then there are the so called "placebo tweaks", very small ones like disabling certain Services, Devices etc. which are useless in many cases. This heavily depends on your system, and some placebo tweaks may help you.
Its bad to generalize tweaks and say "all the tweaks are useless, stop wasting your time". That's simply wrong.
FPSMaster
Re: Useless tweaks.
Post by FPSMaster » 26 Mar 2023, 10:11
Ferr0 wrote:
25 Mar 2023, 21:50
Also most Pro Setups get optimized with all the Tweaks that got prooven to help Latency, actually ^^
Sirito
Re: Useless tweaks.
Post by Sirito » 26 Mar 2023, 16:53
texre wrote:
25 Mar 2023, 20:48
Just go try the game on your friend's house or an internet cafe, if it is the same as on your pc then you know that you fell in the placebo sea, it is as simple as that.
I also recommend taking your mouse and keyboard with you because we don't want these two to be a variable too as different switches or sensors have different feeling and latencies.
Ferr0
Re: Useless tweaks.
Post by Ferr0 » 26 Mar 2023, 19:16
FPSMaster wrote:
26 Mar 2023, 10:11
Ferr0 wrote:
25 Mar 2023, 21:50
I doubt it, they probably do bare minimum but do get the more mainstream things like hyperthreading. Different motherboards also have different stuff enabled by default which contributes to some diversity in setups.
Mugabi
Re: Useless tweaks.
Post by Mugabi » 01 Apr 2023, 17:36
Ferr0 wrote:
26 Mar 2023, 19:16
FPSMaster wrote:
26 Mar 2023, 10:11
Ferr0 wrote:
25 Mar 2023, 21:50
Less than hair minimum sometimes, I know some 6k elo players that literally don’t disable or tweak anything in their windows. Apart from power set to high performance.
