Now I was able to resolve the issue in Win11, I am now able to run the gui version of both tools.
Code: Select all
Set-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Control\DeviceGuard\Scenarios\HypervisorEnforcedCodeIntegrity" -Name "Enabled" -Value 0 -Force -Type Dword -ErrorAction Ignore
Set-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Control\DeviceGuard\Scenarios" -Name "HypervisorEnforcedCodeIntegrity" -Value 0 -Force -Type Dword -ErrorAction Ignore
Set-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Control\DeviceGuard" -Name "EnableVirtualizationBasedSecurity" -Value 0 -Force -Type Dword -ErrorAction Ignore
Set-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Control\DeviceGuard\Scenarios\SystemGuard" -Name "Enabled" -Value 0 -Force -Type Dword -ErrorAction Ignore
Set-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Control\CI\Config" -Name "VulnerableDriverBlocklistEnable" -Value 0 -Force -Type Dword -ErrorAction Ignore
https://rweverything.com/
https://github.com/Faintsnow/HE
But still I am unable to solve the problem of grabbing the remaining address space value. That is the final piece if the steps from djdallmann are correct.
https://github.com/djdallmann/GamingPCS ... al-bus-usb
Well, for AMD I also would need to confirm, because it could have a different value from 24 and even in memory it could be in a different place, therefore have a different value, but not sure.
I am able to code if I find a way to grab the value, but in the memory matter, I have zero understanding, so unless someone else appears to help, not sure that it can be resolved as to know what is the correct value to grab for AMD that is.
