Couldn't find out which USB ports are the CPUs & which are the Chipset's
Posted: 14 Apr 2023, 08:54
Hey there,
I'm a pro VALORANT player and been into these things since way back, figuring out different things from time to time, came across the USB Ports could be causing slight input lag as it takes more time to transmit and receive when it's connected to the chipset's controller rather than the CPU's, my motherboard says
CPU:
3 x USB 3.2 Gen 1 ports on the back panel
1 x USB 3.2 Gen 2 Type-A port (red) on the back panel
Chipset:
1 x USB Type-C™ port on the back panel, with USB 3.2 Gen 2 support
2 x USB 3.2 Gen 1 ports available through the internal USB header
2 x USB 2.0/1.1 ports on the back panel
Chipset+2 USB 2.0 Hubs:
8 x USB 2.0/1.1 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
there are many of them which are the same, so I had to use USB Device Tree Viewer to figure out, Now I want to know which CPU controller is which, the top one or the lower one, I assume its the top cuz it has the prioritized PCI Busing which is Number 1, while the other one is PCI Bus 7
also, I used Device Cleanup tool to clean all unused device entries.
Also, Higher DPI causes less input lag than 400 DPI for example? or is it the same since the mouse displacements are the same?
for example
Which is better?
400 DPI and 0.8 ingame OR 1600 DPI and 0.2 ingame?
EDIT: Came across a Topic that says I should use triple digits+ in ingame sensitivity, for example @400dpi - 0.800 or 0.801 if it doesn't work, did I understand this correctly? or I misunderstood something!
<3
CPU:
Chipset:
for example
Which is better?
<3
