For some reason i donot believe this buffer tweak works tried it multiple times over the years usually i see worse performance instead i would suggest you turn on offloadingSebichek45 wrote: ↑28 May 2023, 11:06sherifmagdy32 wrote: ↑26 May 2023, 10:47Yes you can use this config no matter what power plan you are on let me know how the game feels after you use itSebichek45 wrote: ↑26 May 2023, 05:00sherifmagdy32 wrote: ↑25 May 2023, 21:44Since a lot of people having problems with VALORANT
i wanted to share this config with you
this will mostly help people with mid to low tier PC or on laptops
most of these values works for any Unreal Engine game
when it comes to hitreg issue i recommend trying warp
with this setting as this has the lowest impact when it comes to latency
this should fix most routing and bypass most ISP's throttling
(Preference -> connection -> DNS protocol -> HTTPS)
https://1.1.1.1/
use this to get free GB
https://github.com/TheCaduceus/WARP-UNLIMITED-ADVANCED
make sure to make a backup in case you didnot like the settings for some reason
config file location "C:\Users\UserName\AppData\Local\VALORANT\Saved\Config\"
sort by date modified open the latest one then open Windows folder if you cannot find it go to the next folder in order till you find it
you should find the config file inside the Windows folder
config
https://drive.google.com/file/d/1xOGBkE ... sp=sharing
virustotal scan
https://www.virustotal.com/gui/url/47eb ... ?nocache=1
Can this be used with your power plan?
I think it did something. Shots feel more like it hits. However, currently my game is like me feeling more sharp but the enemies also feel more fast and sometimes I die even before I hear the sound of me dying or them swinging.
Maybe its because of my buffers? Currently on 512/256 no rss.
Also is the gameuser config normally empty? Its empty on an account config folder (the jumbled numbers one) but for the pc itself where it inly has gameuserconfig and no riotusersettings it has values in it. Where should I paste it? Should I set it to read-only?
and try interrupt moderation On it made difference for me on fortnite
