What would the cause of this be ?
Bobo
Post by Bobo » 01 Jun 2023, 08:52
I decided today to plug in my phone charger (turbo charging) in my dedicated power line that i use for my setup, and for some reason there is increased ghosting on my monitor.
obviously i did A/B testing with someone else next to me, and they agreed that there is increased ghosting.
so my question is, what would be the cause of this, is it like a voltage issue or something ?
deama
Re: What would the cause of this be ?
Post by deama » 01 Jun 2023, 09:33
Higher interference in the line caused by additional electronics.
Usually the more power it consumes, the more interference it produces within the line.
Ragerlis
Post by Ragerlis » 01 Jun 2023, 10:39
Likely interference, usually the first steps to check it/fixes are grounding the outlet and using filtering capacitators, its a common problem in industrial environments.
In your case, a simple good quality line filter should do the trick.
