keyboard debounce/latency
vyce
Post by vyce » 06 Jun 2023, 09:12
i bought dark project kd87a, it has optical switches, and the build quality is really good, but there is a problem - there is some input latency, that is noticeable in games.
my old hyperx alloy origins has no such problem, but i absolutely hate this keyboard.
i've figured out that the problem is in the pcb, but i have no idea is it even possible to fix
both keyboards have 1000hz polling rate btw
dougg0k
Re: keyboard debounce/latency
Post by dougg0k » 06 Jun 2023, 12:13
Try and see if will make any difference https://github.com/dougg0k/gaming_os_tw ... pheral.cmd
Post by Slender » 06 Jun 2023, 13:08
vyce wrote:
06 Jun 2023, 09:12
i have kd1b, good looking board, but yes, inputlag a lot.
you can resolve this to set 125hz in hidusbf.
https://blog.seethis.link/scan-rate-estimator/
MatrixQW
Post by MatrixQW » 06 Jun 2023, 13:21
Will depend on the quality of the electronics it seems.
Also check this:
Chief Blur Buster wrote:
16 Oct 2020, 00:29
TIP: Always put high-Hz keyboard and high-Hz mouse on SEPARATE DEDICATED USB CHIPS
Problem: High-Hz poll performance interference between 1000 Hz keyboard + 1000 Hz mouse
I took the easy route and bought a ps/2 keyboard for 5€ instead of spending 100€.
vyce
Post by vyce » 06 Jun 2023, 14:39
Slender wrote:
06 Jun 2023, 13:08
vyce wrote:
06 Jun 2023, 09:12
okay so i did it, idk if it actually works or it's just placebo, but it SEEMS to be a little faster
also, should i check "filter on device"?
Post by Slender » 06 Jun 2023, 17:49
vyce wrote:
06 Jun 2023, 14:39
Slender wrote:
06 Jun 2023, 13:08
vyce wrote:
06 Jun 2023, 09:12
yes, you need filter on device, without it it change usb port (not device)
anyway, by def binterval=1 (1000hz/1ms) but you dont get 1ms / 1000hz (because internal keyboard bug or like that), but if you setting it to binterval=8 (125hz/8ms) keyboard work on it.
check it on site (my previous post)
andrelip
Post by andrelip » 06 Jun 2023, 23:24
For me, keyboard latency is almost unnoticeable. I had the gold standard of 20 years ago like the Logitech Elite, then a Steelseries, Razer BlackWidow, 2 Corsair k70, and Apex Mini. Now I have the Wooting 60HE considered the best low latency keyboard and a Magic Keyboard from Apple with more than 20ms of latency.
Guess what, I’m preferring the Magic Keyboard (on cable).
vyce
Post by vyce » 07 Jun 2023, 05:15
andrelip wrote:
06 Jun 2023, 23:24
wish i could order wooting, but i live in Russla, so that's gonna be pretty difficult and expensive
i'd rather order xtrfy k5, because 60% keyboards are really inconvenient for me, and full size is useless
Post by Slender » 07 Jun 2023, 20:25
vyce wrote:
07 Jun 2023, 05:15
andrelip wrote:
06 Jun 2023, 23:24
try fl esports (na alike vbey, vrode norm bordi)
F1zus
Post by F1zus » 08 Jun 2023, 16:22
Slender wrote:
06 Jun 2023, 13:08
vyce wrote:
06 Jun 2023, 09:12
Hello. I also have a kd3b keyboard and it has a slight delay. Tell me what do you mean by hidusbf? Need to download a modified driver from here https://www.overclock.net/threads/usb-m ... z.1589644/ ?
Or is it enough to download the software for the keyboard and change the polling frequency in it?
I changed the polling rate to 125Hz on the keyboard but didn't notice any difference.
