Valorant issues always come back
Posted: 05 Oct 2023, 20:45
Hey, guys I don't know, but my game feels like absolute garbage sometimes.
A bit off topic: I'm a high elo player, and I want to go pro, but this issue literally makes me crazy. I used to play 15+ games a day, but now I can't handle even 5, because of the issue. Because instead of playing, I'm searching for answers.
-So what is wrong?
- The game feels like 60hz, even though I have a 360 hz monitor. It's not smooth and I would say a little jittery, delayed, laggy, literally I can't react to enemies. It's hard to describe, but the game is becoming choppy for no reason, unless I change something within my PC, e.g. the nvidia driver or set it to another core and so on.
And how do I realize that the problem always comes back? ( and it always does after a couple of hours or days, or sometimes after a reboot).
So, when I begin to move my mouse really fast from left to right, I start to feel dizzy, due to a completely blurry or laggy feeling on the screen, and usually I immediately quit the game to find a temporary solution to this issue.
It either the game network problem, which makes the game unplayable and I can't fix that, because it's related to the Riot servers, or my PC, but I have tried different custom isos, different drivers, different tweaks and at this point I think almost everything I could possibly think of. And there is no way it's unfixable, due to the fact that after finding a temporary solution the game starts to work smoothly.
And the G-sync + V-sync and cap fps doesn't help.
My specs:
Processor: i9-9900k
RAM: Patriot Viper Steel : 16 GB 3800 (16-16-16-36)
Monitor: DELL Alienware 2521h
DATA: SSD ADATA XPG SX8100 512GB M.2 NVMe
Power Supply: 750W CHIEFTEC Power Smart GPS-750C
Video Card: MSI GeForce GTX 1080 ti
And I'm using : G-wolves HTS Plus 4000 polling rate mouse ( playing on 4k)
right now using custom windows Windows 10 22H2
In-game settings:
Everything is low, native 1920x1080.
Nvidia settings:
https://imgur.com/gallery/G1L95ML - old
https://imgur.com/gallery/y6utCYk - new
And sometimes which is ridiculous but the game works pretty fine after a couple of tweaks. But what is not fun is after changing those settings my game runs smoothly straight up for a couple of days or hours and then the problem comes back.
So what I have tried already:
1) Tried Fullscreen Exclusive:
disable-fse-and-allow-gamebar
enable-fse-and-disable-gamebar
And both disabled- is better for me.
2) Win32PrioritySeparation ( default was 26 hex, I figured out that and 2a hex is better and I have lower latency and faster responsiveness) Currently using only '2a'.
3) Changing the video driver: I have tried a lot of them. 512.95, 522.25, 537.34 and 546.01 were the most stable lately. But I'm still trying to find the best one, because fps and smoothness vary a lot depending on the driver like 9k and 3k 0.005%low fps in lava-triangle.
(NVCleanstall+DDU)
- Ansel disabled
- Driver telemetry disabled
- HDCP also Disabled
- Change resolution: using NVIDIA color settings
- Adjust Desktop Color settings : only digital vibrance on 58%
- Adjust desktop size and position : Full screen mode, Perform scaling on : Display
- G-sync : off
- Adjust video color and settings : with Nvidia settings to full
- adjust video image settings: using NVIDIA settings and unchecking Deinterlacing.
+Disabled Dynamic state 1
+Disabled CUDA - Force P2 State
Locked GPU clock and memory clock: https://imgur.com/gallery/AU2xmPH
https://imgur.com/gallery/nMdzIZa
4) Tried HAGS and without it the game feels better.
5) Tried disabling HPET. Didn't do anything.
6) Game mode and Game DVR both off.
7) Affinity tool. I have Tried many things, and it's really making a huge difference, and right now I have only USB and Video card on last core.
8) Msi mode: https://imgur.com/gallery/pZSctyr
9) Network: My ping in the game is 35-50 depending on the servers.
Receive buffers: 256 and Transmit buffers: 512.
Flow control: Disabled
Interrupt moderation Rate: off
Packet Priorirt and VLAN: Enabled both
RSS: enabled
TCP Checksum Offload (IPv4)
Enabled
TCP Checksum Offload (IPv6)
Enabled
UDP Checksum Offload (IPv4)
Enabled
UDP Checksum Offload (IPv6)
Enabled
Large Send Offload V2 (IPv4)
Disabled
Large Send Offload V2 (IPv6)
Disabled
all wake up on and Idle power savers are off as well.
While playing I have no packet loss. And ping is stable +-1ms.
Tried Vpn ( didn't help at all) and warp as well.
Tried Clumsy, to be fair, having higher ping gives advantage at some point,so I didn't use it for most of the time( 2 times I have used it) , but it was worth trying. Thanks to 13n47.
10) Tried the Nvidia Inspector and custom settings from CatGamerOP: https://drive.google.com/drive/folders/ ... YW7HP_aEAc
11) Used tcp optimizer here’s the settings:https://imgur.com/gallery/wlDX2NZ
12) Tried using low and high dpi and - no difference.
13) While Playing, I rarely use Discord and maybe Obs to record the gameplay, so there is nothing in the background 99% of the time, not even chrome.
14) Tried to use PowerSettingsExplorer.exe To change Processor performance time check interval to 5000ms and Processor idle Disabled: https://imgur.com/gallery/iiDbSwY
15) Tried PolicyPlusLatest.exe : https://imgur.com/gallery/ZhGACb8
16) Tried different configs. Tried deleting game config through AppData .
17) I have disabled the Disable Hyper-threading / Simultaneous Multithreading (SMT) in UEFI
Disable power saving features like C states, Virtualization and so on.
18) Overclocked my CPU to stable 4800 core clock and 4400 ring clock: https://imgur.com/gallery/KWNn7ni
19) Triad SCEWIN and disabled a lot of power saving using this guide from Des1de & CatGamerOP: https://docs.google.com/document/d/1KIW ... aBD4E/edit
20) And the ram. Lately, I tried to tighten all the timings and here is the result: https://imgur.com/gallery/j6mpJNH.
I saw a post from GUIDE by KoT that tWR/tRTP can affect smoothness and I increased my 12 tWR/6 tRTP to 20 tWR/10 tRTP - again couple of days of stable smooth work and then the problem came back again.
I genuinely have no idea how to fix the issue, because it always comes back in less than a couple hours or days. It's one of the most annoying things to have when you have a butter smooth game and then it disappears like nothing happened.
-So what is wrong?
My specs:
Processor: i9-9900k
In-game settings:
Nvidia settings:
(NVCleanstall+DDU)
- Ansel disabled
- G-sync : off
RSS: enabled
Enabled
Enabled
Enabled
Enabled
Disabled
Disabled
