Valorant input lag
rooy
Valorant input lag
Post by rooy » 24 Jan 2024, 10:16
Well. Hello. im new here.
i try to troubleshoot my input lag in valorant
my pc specs is
Cpu : i7 7700k
Ram: 16GB 3200mhz
ssd: m2 samsung evo 250gb
Gpu 1070 msi 8gb
psu corsair 860i platinum
mouse : razer viper v2 pro 8000hz
keyboard : corsair k65 mini 60 % 8000hz
monitor: alienware 25' 360hz
second monitor alienware 240hz
connected with displayport.
im good player but in several games they ferrari peak me.
I tried calypso guide. helped a bit but im feeling the input lag.
i tried paid adamx programm.
i tried different usb ports for mouse and keyboard seperate .
i change my mobo screws for better grounding .
i dont know what else... now i changed place.. i dont know if is emi related problem i will test today...
anyone can help ?
Re: Valorant input lag
Post by RealNC » 24 Jan 2024, 11:23
Just to make sure it's not display or polling rate related, do these things:
* Set mouse to 1000Hz
* Set keyboard to 1000Hz
* Disconnect the second monitor and use only one
Reboot and see if it's better.
RealTweaker
Post by RealTweaker » 24 Jan 2024, 16:02
What is your Samsung Evo M2 SSD model? Some of them don't have official drivers so u forced to use default Microsoft NVMe driver which slows down the SSD and therefore the whole system. There's a way to fix that completely. Just download install Intel NVMe driver, make sure it's not 3.3 but 3.1 version.
Samsung nvme controller version 3.3 - this driver has potential to cause a heavy mouse, I discovered this by accident on a new install after reading another members post.
Guide: little fix for users that have nvme without drivers
A thread with tweaks for Valorant: Input / Fps lag / polling issue / latency fix vault (valorant based)
rooy
Post by rooy » 25 Jan 2024, 09:03
samsung evo plus 970 250gb
BlurWickd
Post by BlurWickd » 26 Jan 2024, 23:52
RealTweaker wrote:
24 Jan 2024, 16:02
I think this quote was from my thread, I personally tried the intel nvme driver and didn't have good results. Best results was with the windows drivers actually, everything else including the 3.1 version gave me bugs. I switched out ssds in the end.
OP can you confirm if you're on windows 11 or windows 10? do you have realtek audio / corsair icue / razer synapse installed? any rgb programs downloaded? is this an issue only in valorant? which network adapter (nic) do you have?
rooy
Post by rooy » 27 Jan 2024, 04:21
BlurWickd wrote:
26 Jan 2024, 23:52
RealTweaker wrote:
24 Jan 2024, 16:02
im also feel it better without driver!! im on windows 10
Realter audio not installed for sure because im using external audio card (sound blaster z pcie)
Icue not installed.I uninstalled razer synapse and all rgb are disabled
i have i219v network adapter and samsung magician closed.
BlurWickd
Post by BlurWickd » 27 Jan 2024, 14:15
rooy wrote:
27 Jan 2024, 04:21
BlurWickd wrote:
26 Jan 2024, 23:52
RealTweaker wrote:
24 Jan 2024, 16:02
Samsung magician gave me heavy mouse not sure why, do you have the latest network adapter drivers?
rooy
Post by rooy » 27 Jan 2024, 14:23
BlurWickd wrote:
27 Jan 2024, 14:15
rooy wrote:
27 Jan 2024, 04:21
BlurWickd wrote:
26 Jan 2024, 23:52
RealTweaker wrote:
24 Jan 2024, 16:02
i format my pc now. not yet im trying with stock
i closed the updates after format . zero updates
InputLagger
Post by InputLagger » 05 Feb 2024, 16:04
rooy wrote:
27 Jan 2024, 04:21
BlurWickd wrote:
26 Jan 2024, 23:52
RealTweaker wrote:
24 Jan 2024, 16:02
I have the same sound card. I had many issues with their panel, drivers and stuttering sounds robovoice, microphone along with Windows / discords / team speaks whatever. Weird card. Give a try to disconnect the card completely with driver uninstalling and try to play with onboard audio with generic / from mobo website audio drivers
rooy
Post by rooy » 06 Feb 2024, 05:37
InputLagger wrote:
05 Feb 2024, 16:04
rooy wrote:
27 Jan 2024, 04:21
BlurWickd wrote:
26 Jan 2024, 23:52
RealTweaker wrote:
24 Jan 2024, 16:02
did u update to latest version through the programm ?
mine works flawless
