pch core voltage
pox02
pch core voltage
Post by pox02 » 20 Mar 2024, 22:57
this voltage cause mouse jitter if its not set correctly my mouse move so weird after i got 10900k and xii apex the default is 1.05v increase it to 1.2v fix it pch core voltage is the reason of usb jitters and move incorrectly even if your cpu is stable i suggest try 1.1v 1.15v if its not fixed increase it to 1.2v can fix it
n1zoo
Re: pch core voltage
Post by n1zoo » 22 Mar 2024, 15:23
raising the voltage will only have a temporary effect as with all things software, hardware related
pox02
Post by pox02 » 26 Mar 2024, 21:34
n1zoo wrote:
22 Mar 2024, 15:23
thats correct ! but i found the problem its was usb/pcie pll voltage default was 1.090v increase it to 1.150v feels like pch on 1.2v now i can use pch voltage on auto and usb/pcie pll voltage on 1.150v
