Guys, try it, I think I always tried to remove the USB port driver, but this method helped me remove the floating mouse.
gideonmontes
Post by gideonmontes » 07 Apr 2024, 03:00
Source: https://www.reddit.com/r/MouseReview/co ... _my_mouse/
press windows + x (or right click on the windows icon on the taskbar)
select Device Manager
click on Universal serial bus controllers
right click on Intel(R) USB 3.0 eXtensible host controller - 1.0 (Microsoft)
click uninstall device
your mouse and keyboard should be disabled. now press the power button on your pc to do a shutdown or hold it for 7 seconds to do a force shutdown.
unplug your mouse and keyboard, give it a good minute or so and then turn the pc back on.
when the pc is turning on, you might get a message from your bios saying that a keyboard is not detected but thats ok, plug your mouse and keyboard to your pc and you should be good to go.
gideonmontes
Re: Guys, try it, I think I always tried to remove the USB port driver, but this method helped me remove the floating mo
Post by gideonmontes » 07 Apr 2024, 03:15
By the way, in my opinion, the situation with registering damage has also been corrected, at least I have never died behind a wall.
Mr1991
Post by Mr1991 » 07 Apr 2024, 18:34
We’re in desperate need of a new dedicated system for input devices, it’s clear the usb system is majorly flawed for mouse input and shouldn't be affected by things like this
ahead
Post by ahead » 11 Apr 2024, 04:47
Yes, that's true. There's only a 5ms delay, which you would never detect in any blind test—believe me! ;)
Imperator
Post by Imperator » 11 Apr 2024, 05:34
On PS/2, it rips off the mouse sensor in FPS games
Mr1991
Post by Mr1991 » 12 Apr 2024, 17:40
ahead wrote:
09 Apr 2024, 01:52
we already have https://en.wikipedia.org/wiki/PS/2_port
An updated version would be good
The ps/2 comeback
ahead
Post by ahead » 12 Apr 2024, 19:56
You can't remove any driver; you can only replace one driver with another. This is how the operating system works.
Post by Slender » 12 Apr 2024, 20:16
ahead wrote:
12 Apr 2024, 19:56
he is "uninstall" driver from device manager, thats not remove.
