Animation Time Graph Spikes Normal ?
NHP
Post by NHP » 25 Nov 2024, 21:45
Hi everyone,
I am sorry if this isn't the right place to ask about this, but hopefully it is.
I am wondering if such spikes on the Animation Time Graph are normal and not to be worried about ? I Fresh installed windows, installed necessary drivers, but no RGB software or anything else optionnal, and still got them.
Although, I still manage to get a flat graph for a few seconds, the screenshots are really taken in moments wherethese happen, but in between there would be 30, 20 seconds of flat grapph
Screeshot 01
Screeshot 01
Screenshot 01.png (38.39 KiB) Viewed 1247 times
Screeshot 02
Screeshot 02
Screenshot 02.png (36.23 KiB) Viewed 1247 times
Screeshot 03
Screeshot 03
Screenshot 03.png (26.07 KiB) Viewed 1247 times
(Screenshots in attachement)
Re: Animation Time Graph Spikes Normal ?
Post by RealNC » 25 Nov 2024, 22:01
Yeah, it's fine. Especially when not using the "ultimate" power plan in Windows (preventing CPU power saving, core parking, etc.) and having something else open as well, or Windows background processes that use the CPU from time to time. The browser itself as well (it periodically writes data to disk, at a pace of like 200kb/s, all the time non-stop.)
I would say getting a perfectly flat graph for an extended period of time is pretty much impossible on modern Windows versions and modern browsers. They just do way too much crap in the background all the time.
NHP
Post by NHP » 25 Nov 2024, 22:16
Thanks a lot for your reply RealNC. That's helpful!
Good to know, I am using balanced mode because I have 7950X3D, but I'll give the high Performance mode a try!
Post by Chief Blur Buster » 26 Nov 2024, 00:09
This graph is generally pretty much fine.
This is generally good if you do not see very frequent (every 1 second) red spikes with an idling browser as the foreground app.
Browsers are simply a canary in the coal mine, they can often be more sensitive to stutters than many DirectX/Vulkan/OpenGL games. It's great when you need to diagnose a "I've got a really nasty background process that even a webapp can 'see' the jitter of" problem (like background RGB software).
Some demo kiosks and display reviewers use custom slimmed-down Windows installs (even dual boot to them) as well as game-optimized OSes to try to calm down this graph, to make TestUFO run really smooth.
Performance Mode and Ultimate Performance help, as does raising the priority of foreground app. That said, Chrome run a lot of background apps that have varying levels of priorities.
NHP
Post by NHP » 26 Nov 2024, 21:11
Hi there!
Thanks for answering! Yeah, when idling, I don't ge any stutter warnings and spikes never exceed green color, unless I mvoe my mouse around the tabs or things like that where it feel like it makes sense tha it unsyncs.
However a quick question, the reason i'm looking at all these blur buster tests, in some games, on my 144Hz monitor, when capping fps, there is a massive amount of screen tearing (Counter Strike 2 ; League Of Legends ; ...) However, when I unlock FPS it's much much smoother. Isn' this counter-intuitive ???
Sorry if this thread is going somewhere else haha! :mrgreen:
Post by RealNC » 26 Nov 2024, 21:15
NHP wrote:
26 Nov 2024, 21:11
Without vsync (or any form of sync) there's gonna be tearing. FPS capping and syncing are different things. When tearing, the higher the FPS, the less noticeable tearing becomes. But it's always gonna be there, unless you start using some form of sync (vsync, g-sync, freesync, etc.)
NHP
Post by NHP » 26 Nov 2024, 22:28
RealNC wrote:
26 Nov 2024, 21:15
NHP wrote:
26 Nov 2024, 21:11
I totally understand what you're saying, however, I am using the same screen I was using on a previous 1080ti build and I am noticing so much more screen tearing with this new 4080super build. I don't get it, it's like waaay too obvious. Perhaps, my monitor is bad ? (MSI g241)
Post by RealNC » 26 Nov 2024, 22:54
NHP wrote:
26 Nov 2024, 22:28
Maybe you had g-sync enabled?
Edit:
Oh, wait. 10 series cards don't support MPO (multiplane overlays.) So you might have been vsynced with the 1080 Ti when not using exclusive fullscreen. The 4080 S supports MPO, which means it's possible to have vsync off even without exclusive fullscreen, especially in Windows 11 where this happens even in non-borderless windowed mode. (In Windows it's possible with some games in borderless windowed mode.)
Or you might have been using g-sync and it has nothing to do with MPO or Windows 11.
dervu
Post by dervu » 29 Nov 2024, 15:30
I noticed this test not having any yellow/red spikes at all when running over 10 seconds with nvidia power management mode set to full performance for chrome, but when I set nvidia power management mode to normal there are both yellow and red spikes pretty often.
It's reproductible every time.
Would GPU performance matter so much?
It's not like PCI-E speed would drop or anything. Only GPU memory and core speeds drop.
Ryzen 7950X3D / MSI GeForce RTX 4090 Gaming X Trio / ASUS TUF GAMING X670E-PLUS / 2x16GB DDR5@6000 G.Skill Trident Z5 RGB / Dell Alienware AW3225QF / Logitech G PRO X SUPERLIGHT / SkyPAD Glass 3.0 / Wooting 60HE / DT 700 PRO X || EMI Input lag issue survivor
Post by RealNC » 30 Nov 2024, 03:27
dervu wrote:
29 Nov 2024, 15:30
It's probably the actual clock switching that might cause the spikes.
