Blur Busters Forums
CSGO less threads[cores] less input lag?
Re: CSGO less threads[cores] less input lag?
Postby flood » 04 Feb 2015, 14:36
sega4ever wrote:
flood wrote:idk i think quake and cs1.6 are way smoother than csgo
probably something to do with the fixed framerate
Can't you just use the fps command to set a max frame rate?
yea its possible to use fps_max but the variability of the frame times is quite a bit worse than in 1.6
pretty easy to check with a fraps benchmark
flood
Postby RealNC » 05 Feb 2015, 06:32
1.6 is just as variable on my Pentium 2 400MHz, which is what the game was made for ;-)
I'm pretty sure that CS:GO will run just as well as 1.6 on a PC made 15 years from now.
Postby stirner » 05 Feb 2015, 13:37
But in 1.6 the framerate is synchronized to tickrate. You notice that when you lag and drop frames and when you go above tickrate amount of frames via developer 1 - which changes the physics of the game.
In GO every client frame is not a tick frame but an interpolated frame, which has its advantages but also means the rendering interval is more dependent on your system.
I think 1.6's single-core rendering vs. GO's multi-core rendering is really the culprit messing with consistent frametimes though.
stirner
Postby lexlazootin » 05 Feb 2015, 20:11
port csgo to goldsrc. GG Volvo.
lexlazootin
Postby br00m » 19 Apr 2017, 15:31
Has there ever been a fix to CSGOs sluggishness?
br00m
Postby RealNC » 19 Apr 2017, 19:19
br00m wrote:Has there ever been a fix to CSGOs sluggishness?
Yes. Buying a good PC. If you run on a potato machine that's not meant for games, you can't expect a good gaming experience.
CS:GO is one of the best optimized games out there. If your PC can't run it well, you must be on a machine from the previous decade or something.
Postby br00m » 20 Apr 2017, 21:27
I have a i5 2320 which is a 3 Ghz quadcore and a HD 7850. I get at least 200 FPS on lowest settings. A friend of mine has a better pc (2500k and a gtx 680) and he also feels like CSGO is sluggish. Im not sure if a good PC fixes this.
br00m
Postby RealNC » 21 Apr 2017, 02:44
br00m wrote:I have a i5 2320 which is a 3 Ghz quadcore and a HD 7850. I get at least 200 FPS on lowest settings. A friend of mine has a better pc (2500k and a gtx 680) and he also feels like CSGO is sluggish. Im not sure if a good PC fixes this.
Does "fps_max 140" fix it? If not, then I don't know.
Postby br00m » 28 Apr 2017, 16:50
No, unfortunately not. Thank you anyways for your effort. I guess I buy a better PC soon, it really seems to be my hardware/settings.
br00m
Postby mindovic » 12 May 2017, 04:54
br00m wrote:No, unfortunately not. Thank you anyways for your effort. I guess I buy a better PC soon, it really seems to be my hardware/settings.
Try lowest settings, for example FXAA adds input lag because it's post process AA.
mindovic
PreviousNext
Return to Input Lag
Who is online
