Blur Busters Forums
Post-Processing and Input Lag
Postby coolitic » 25 Mar 2017, 18:20
Can someone please explain to me how post-processing affects input lag (preferably in great detail), especially with multiple effects and how they interact with each other.
Re: Post-Processing and Input Lag
Postby lexlazootin » 25 Mar 2017, 22:06
The more framerate you loose, the more latency is added. I believe you can do a quick 1/FPS (or looking at the frame times) for determine how much latency on average is added to your graphics chain.
I don't think Post Processing adds any inherent latency beside the performance it takes away.
Edit: I found a post a while ago where they talk about this since i'm not the most educated in graphics pipelines and whatnot: ... =10&t=2748
Postby sharknice » 26 Mar 2017, 20:16
Yep, it doesn't do anything special, it just adds to the overall frame render time.
Return to Input Lag
Who is online
Users browsing this forum: Baidu [Spider], Bing [Bot] and 1 guest
