Post-Processing and Input Lag
PostPosted: 25 Mar 2017, 18:20
by coolitic
Can someone please explain to me how post-processing affects input lag (preferably in great detail), especially with multiple effects and how they interact with each other.
Re: Post-Processing and Input Lag
PostPosted: 25 Mar 2017, 22:06
by lexlazootin
The more framerate you loose, the more latency is added. I believe you can do a quick 1/FPS (or looking at the frame times) for determine how much latency on average is added to your graphics chain.
I don't think Post Processing adds any inherent latency beside the performance it takes away.
Edit: I found a post a while ago where they talk about this since i'm not the most educated in graphics pipelines and whatnot: https://forums.blurbusters.com/viewtopi ... =10&t=2748
PostPosted: 26 Mar 2017, 20:16
by sharknice
Yep, it doesn't do anything special, it just adds to the overall frame render time.
