XL2540 Button-to-Screen Input Lag Test?
omgeez240hzs
Post by omgeez240hzs » 01 Nov 2017, 16:38
Has anyone done button-to-screen input lag tests for the BenQ XL2540 at 240hz?
I found some good stuff on 240hz for the Acer Predator here, but not the XL2540:
http://www.blurbusters.com/gsync/gsync101-input-lag/
Here I found discussion on 60hz input lag tests for the xl2540 which seem pretty invalid.
viewtopic.php?t=3116
I'm hoping to find some stats tested at 240hz with and without the hacked blur reduction...any help is appreciated. Or if this can be done DIY for <$100 I might be interested in to putting in some research and performing the tests myself. Thanks for any help/info.
lexlazootin
Re: XL2540 Button-to-Screen Input Lag Test?
Post by lexlazootin » 01 Nov 2017, 18:26
If you just wanted to know the awnser I can tell you it's going to be as low as every other 240hz monitor, they don't really vary much interms of input latency.
But I think chief was going to make a sellable input latency tester device if I recall correctly, maybe I'm wrong.
Sparky
Post by Sparky » 01 Nov 2017, 21:25
omgeez240hzs wrote:Has anyone done button-to-screen input lag tests for the BenQ XL2540 at 240hz?
That it can. Everything needed should be less than $50.
Microcontroller that can emulate a mouse(I used an arduino micro, flood used a teensy 2.0)
A basic electronics prototyping starter kit. (assorted resistors, LEDs, switches, jumpers, capacitors, and a breadboard).
An opamp.
A photoresistor, photodiode, or phototransistor. (photoresistor is slower, but simpler to implement)
Here's flood's thread, there is a post with his code somewhere in there, along with discussions about developing the testers: viewtopic.php?f=10&t=1381
Here is the post that explains how I built mine(including code), and there's more discussion in this thread: viewtopic.php?f=10&t=3005&start=50#p22634
