gpu/display scaling input lag
Trying to tweak my settings to get the lowest input lag possible. Read on this forum that scaling lag is dependent on the scaler in your gpu/display and i'm not sure which one is faster in my case. But my question is does it really matter which one I select in nvidia control panel when I use my native resolution? Does scaling even happen then?
Re: gpu/display scaling input lag
Why would scaling be performed n that case? What would, in your opinion, be scaled to what?Frs4ken wrote:But my question is does it really matter which one I select in nvidia control panel when I use my native resolution? Does scaling even happen then?
