Fast sync+ lightboost with uncapped fps
Posted: 26 Jul 2018, 17:20
by kevzz01
Anyone running this setup? I’m playing PUBG with uncapped fps(144 is max) and fast sync on. Is this a good setup for an fps game? Does lightboost reduce the motion blur with this setup?
Re: Fast sync+ lightboost with uncapped fps
Posted: 27 Jul 2018, 10:43
by RealNC
It's fine.
Posted: 27 Jul 2018, 11:59
by Sparky
It's ok, but with fast sync you generally want to cap framerate at the highest sustainable multiple of refresh rate.
Posted: 27 Jul 2018, 14:11
Fast Sync looks good with LightBoost if you cap your framerate to equal refresh rate, or a multiple (twice refresh rate).
You have microstutter harmonics (beat-frequency effects) between frame rate and refresh rate.
And blur reduction (LightBoost/ULMB/strobing) amplifies the visibility of stutter. That's why strobing (LightBoost, ULMB, etc) looks more jittery.
To fix that with strobing while avoiding adding on too much VSYNC ON lag -- it is preferable to have "frame rate = refresh rate = strobe rate" -- and for slightly lower input lag with Fast Sync without adding strobed jitteriness -- try a frame rate cap of double the refresh rate when using Fast Sync (or the new graphics-card-independent RTSS Scanline Sync feature, to simulate NVIDIA Fast Sync or AMD Enhanced Sync)
