Hello,
i hope someone of you can help me.
Since a few weeks i have an input lag, or mouse lag. I dont know how it is exactly called. The mouse lags sometimes, when i open something of my 2 monitor. It wasnt often and it was ok for me. But now i have a triple monitor setup, and this happens quite more often. Now when i step forward in a youtube video on one of the monitor, and nothing else is running it has a tiny mouse lag, which shows, that the system lags or whatever.
How i can fix this ?
My computer Settings are:
i5
GTX 1070
1 Monitor 1920 x 1080 over HDMI
2 Monitor 1920 x 1080 over DVI
3 Monitor 1920 x 1200 over DVI ( this is widescreen, will it bringt something to swap him to 1080 ) ?
All of this monitors are nearly 5 or more years old.
Im a newbie on the hardware thing, and i dont know how to fix this mouse lag.
Hope someone of you can help me.
Ambro
Mouse Lag, Triple Monitor Setup
Re: Mouse Lag, Triple Monitor Setup
Are they all running at the same refresh rate and setting?
-- Configure all of them to the same refresh rate
-- Turn off windowed GSYNC
Sometimes, divergent monitor settings can slow down the framerate of another monitor, and really lag things very severely.
At times, if you are playing an eSports game, temporarily turn off all secondary monitors and game with only one monitor.
Latency problems in divergent-multimonitor setups are extremely common. One solution is to use DisplayFusion shareware software to turn on/off secondary monitors via a hotkey or via a specific application launch -- this can help.
2 Monitors are at 60hz,
1 Monitor is at 59hz, but i wont think its 59hz, its 60 and a display failure or ?
But i the future i want to buy a Monitor with 144hz or 165hz so this would be a bigger problem ?
i actually dont have gsync monitors so its off.
I dont play compative eSport, and i want to have all active even when i play. Cuz i have a guide there open, or reading something, or a movie etc.
So this isnt a RAM problem or something ?
i will try display fusion for some uses. Ty for your help!!
