Blur Busters Forums
Help me :( ...I'm lagging if everything is set "High"
Postby Kaggewas » 05 Jan 2019, 07:40
Hello, I have such a problem, I don’t know why, but I’m not comfortable playing games, I just decided to compare my game at 120-140 fps with a video where the game goes at 60-80 fps, everything goes much more smoothly and especially at high settings. and I play at the minimum settings, but I cannot play at the maximum, I have a monitor of 240 hertz, if I put everything on high, there will be a feeling that the game is starting to lag ...
Kaggewas
Re: Help me :(
Postby Chief Blur Buster » 06 Jan 2019, 01:47
What monitor model do you have?
What game are you playing?
When you say "If I put everything on high", do you mean high graphics detail?
Your framerate will fall, and your lag is because of the low framerate, and not the monitor's fault.
So you will want to upgrade your GPU to prevent framerate from becoming your lag bottleneck.
240Hz can only do so much to fix the input lag of a low frame rate such as 30fps. It can help reduce scanout lag (16.7ms reduced to 4.2ms by going from 60Hz->240Hz), but it won't fix your render lag (1/30sec = permanent 33ms render lag).
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Re: Help me :( ...I'm lagging if everything is set "High"
Postby Kaggewas » 07 Jan 2019, 14:45
ASUS Pg258q
Game: black ops 4
https://youtu.be/ursdazz-qLo
watch the video, here at 60-80 fps the game looks much smoother than mine at 90-110 fps
Kaggewas
Postby RealNC » 08 Jan 2019, 07:35
It's a video, so how do you know it wasn't lagging?
Postby Kaggewas » 09 Jan 2019, 12:17
I do not know, just on the video the game looks smoother than mine :) With the fact that the video has 70 fps, and I have 100-110
Kaggewas
Postby open » 10 Jan 2019, 13:16
Edit: nevermind i misread the post
open
Postby RealNC » 10 Jan 2019, 13:19
If you're on an nvidia gpu, make sure max pre-rendered frames is set to 1 in the nvidia panel's 3d section. Does that help?
Postby Kaggewas » 14 Jan 2019, 03:27
This option is enabled, but it does not help, there is still no smoothness.
Kaggewas
Return to Input Lag
Who is online
Users browsing this forum: No registered users and 5 guests
