Blur Busters Forums
What is the smoothest combo for frame-pacing?
Postby aweigh0101 » 10 Jan 2019, 05:49
Let's put aside lag for the moment and instead I want to know what is the SMOOTHEST most "synced" possible frame pacing combo of settings?
Traditional v-sync ENABLED + (if so desired) a frame-rate cap of choice?
or
Fast-sync ENABLED + Scanline-sync?
For the moment I'm not worried about lag, I want the most buttery-smooth frame-pacing possible. What options would you guys use?
aweigh0101
Re: What is the smoothest combo for frame-pacing?
Postby RealNC » 10 Jan 2019, 06:50
Vsync with an RTSS cap of Hz - 0.01. This gives the most consistent frame pacing in the majority of cases.
Postby Chief Blur Buster » 10 Jan 2019, 12:12
Forgetting input lag completely, and trying to framepace perfectly to refresh rate:
1. Lower refresh rate until refresh rate is matches or below your 0.1% frametime.
As high as possible, but avoiding framerates below Hz 99.9%+ of time.
2. If step 1 results in a low refresh rate (like 60Hz) or not possible,
Then upgrade GPU and/or adjust game detail down.
3. Can use VSYNC ON without a cap. Laggier than RealNC, but zero differential.
When prioritizing refresh-rate framepacing over latency, assuming you succed in (1), it is hard to beat normal VSYNC ON as that is already a framepacing-good (but laggy) cap. Caps may improve or worsen stutter, depending on variables such as how games internally generate their gametimes.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Postby RealNC » 10 Jan 2019, 12:18
Chief Blur Buster wrote:3. Can use VSYNC ON without a cap. Laggier than RealNC, but zero differential.
Caps may improve or worsen stutter, depending on variables.
The suggestion to use RTSS was to improve frame pacing. In just about every game, RTSS improves it to some extent. In some cases the improvement is extreme. The reduction in input lag is a bonus.
I have yet to find a case where not using RTSS with vsync is beneficial.
Postby aweigh0101 » 11 Jan 2019, 04:00
Chief Blur Buster wrote:Forgetting input lag completely, and trying to framepace perfectly to refresh rate:
Sorry I really don't understand point 1... Do you mean make custom resolutions with specified refresh rate that match (or are below) my... what do you mean below my 0.1% frametime?
aweigh0101
Return to Input Lag
Who is online
Users browsing this forum: No registered users and 4 guests
