S-Sync combined with other different syncs?
Litzner
Post by Litzner » 05 Feb 2019, 21:52
I am currently using S-Sync+No-vsync and I noticed there are write ups about how to combine S-Sync with V-Sync and FastSync. I was wondering why you would do this, what advantage or situations would make you want to combine S-Sync with the other syncs? What are the pros and cons of each combination?
Re: S-Sync combined with other different syncs?
Post by Chief Blur Buster » 06 Feb 2019, 02:45
You're probably following the Scanline Sync HOWTO.
The latency differences of all of them is similar (within roughly 1-2ms). What happens is what kind of disadvantage you get when you've got those frametime spikes. i.e. Do you want a tearline during a frametime spike, or do you want a single microstutter during a frametime spike? You choose the con you prefer.
Full framerate
RTSS + Any sync = Identical look with almost identical lag
Framerate Slowdowns
RTSS + VSYNC OFF = tearlines will reappear
RTSS + Fast Sync / Enhanced Sync / VSYNC ON = stutters will reappear
Choose Your Preference
Some people are more sensitive to stutters.
Some people are more sensitive to tearing.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Post by RealNC » 06 Feb 2019, 06:14
Litzner wrote:I am currently using S-Sync+No-vsync and I noticed there are write ups about how to combine S-Sync with V-Sync
You can't do that. S-sync only works when the game is running vsync OFF.
Fast sync works because fast sync still runs games with vsync OFF.
Litzner
Post by Litzner » 06 Feb 2019, 11:12
For me I will take a tear line over a stutter.
Thank you very much for the info!
Litzner
Post by Litzner » 06 Feb 2019, 12:42
And and I want to apologize for this extra thread, I just noticed I completely missed that this was already in a How To :cry:
Litzner
Post by Litzner » 06 Feb 2019, 13:12
One more question, if I can bother further, in combination with Lightboost, if I am running a 2xS-Sync setup, so 240fps@120Hz, is there difference between doing it with NoSync or FastSync+SyncScanLine1?
