Hello guys,
I am completelly new here and I am also an owner of 144Hz monitor, but I never researched on this topic.
I am also strugling with my PC specs to even hit 144+ FPS in some games.
Right now I am trying to optimize my performance for Apex legends, without tempering with the videoconfig files I could hit 80-120FPs.
For me personally it is best so far to lock my FPS to 75, so I dont have any FPS spikes.
Anyway to get back to the original topic, this is my PC:
i5-7600K
MSI GTX 970 4G (3,5G -.- )
16GB RAM
144Hz monitor Samsung C24FG73FQU
I am trying to understand what should be my goals to have the best gaming experience.
Scenario 1.) I will be able to get more FPS than my refresh rate, stable
Scenario 2.) I will be able to get more FPS than my refresh rate, but with drops below refresh rate, example: 130-160fps
Scenario 3.) I won´t be able to get more FPS than my refresh rate, but FPS will be stable
Scenario 4.) I won´t be able to get more FPS than my refresh rate, with FPS drops
I would like to get your insight how to approach every scenario, so I can better understand what each adjustment does.
(I am talking about setting up FPS caps, NVCP V-Sync ON/OFF, in-game V-Sync ON/OFF (For Apex there is more V-Sync options like Adaptive, etc.)
Before trying to fiddle with video config files I had Scenario 4.) as I mentioned on top, so from my personal experience what felt the best was: NVCP V-Sync OFF, game V-SYNC OFF, FPS cap to stable 75 FPS.
But I dont know, that is why Im trying to find better options, this still doesnt feel right and I hope that once I adjust videoconfig files I will be able to hit 144FPS+.
P.S: I know I need to upgrade my video card, I am saving for that.
P.S.S: Sorry for my grammar guys.
Thank you!
Feever
Help to find optimal settings for FPS
Re: Help to find optimal settings for FPS
A locked framerate is typically optimal for consistent aiming in competitive shooters, so if the tearing isn't bothering you, and 75 FPS is the maximum your system can achieve 99% of the time (I'm assuming you have all in-game graphics settings at low already?) for that game, then without VRR (G-SYNC/FreeSync) available to you, that is indeed the best scenario you're currently going to get if you're looking for both the lowest input lag and most consistent aiming experience.
Well on current settings 120FPS is the maximum I can achieve, but then during a gun fight, or when there is a lot of going on I have drops to 75ish FPS, that fast and radical FPS drop was affecting me negatively, thats why I locked it at 75.jorimt wrote:75 FPS is the maximum your system can achieve 99% of the time (I'm assuming you have all in-game graphics settings at low already?) for that game, then without VRR (G-SYNC/FreeSync) available to you, that is indeed the best scenario you're currently going to get if you're looking for both the lowest input lag and most consistent aiming experience.
Do you recommend otherwise?
Also when I get home I will do some additional tweaking and I should get FPS over 144 (my refresh rate), but I am note sure about the FPS drops. Do you then suggest different settings?
What about VSync options?
Right, while 120 FPS may be the maximum you can achieve, I specifically stated if "75 FPS is the maximum your system can achieve 99% of the time," a.k.a. you're average framerate, then, if you want the most consistency, that is what you want to lock it to if you currently get lots of drops at an otherwise higher average framerate.Feevercz wrote:Well on current settings 120FPS is the maximum I can achieve, but then during a gun fight, or when there is a lot of going on I have drops to 75ish FPS, that fast and radical FPS drop was affecting me negatively, thats why I locked it at 75.
Any low lag V-SYNC methods for framerates well inside the refresh rate (75 FPS @144Hz, for instance) are always going to have higher input lag than V-SYNC OFF. So it depends on what you value more: a tear-free experience, or lowest input lag possible. Because without VRR, you can't quite have both of those, at least with fluctuating framerates and/or framerates well within the refresh rate.Feevercz wrote:What about VSync options?
....that said, it is possible to get close (within a sub-refresh cycle) with carefully tuned RTSS scanline sync. That said, it can be fiddly.
Could you expand a bit on this? Close to what exactly?Chief Blur Buster wrote:....that said, it is possible to get close (within a sub-refresh cycle) with carefully tuned RTSS scanline sync. That said, it can be fiddly.
