Multiple Monitors, RTSS and Scanline sync
xyntron
Post by xyntron » 10 May 2019, 16:16
Hi.
I'm was trying to change the Scanline Sync (to move the stuttering line on specific place) to a different value but it doesn't take any visible effects in-game.
I have 3monitors.
Is there any command like:
SyncDisplay=[IndexNumberOfTheMonitor]
in the config file of the examplegame in:
C:/Program Files (x86)/RivaTuner Statistics Server/Profiles/examplegame.cfg
The index number of the specific monitor on which changes will take an effect?
I think it might be the case why I cannot make it work.
I couldn't find any guide which answer my questions so I post it here.
Re: Multiple Monitors, RTSS and Scanline sync
Post by RealNC » 11 May 2019, 10:33
You can add it yourself to "Profiles\Global". It should be added to the "[Framerate]" section.
