Which Monitor Do You Suggest For Using Pc And Console ?
wNchstR
Post by wNchstR » 18 Jul 2019, 07:06
I want to buy 1080p 24" monitor which I mostly use at 60 hz for console and also pc. After doing some reading I cant decide which one I should buy
Asus XG248Q
Viewsonic XG240R
Lg 24GL600F
Asus PG248Q
Which one do you suggest. Thank you.
Notty_PT
Re: Which Monitor Do You Suggest For Using Pc And Console ?
Post by Notty_PT » 18 Jul 2019, 10:45
XG2402, XG240R and LG 24GL600 are your best bets for both console and pc gaming with good future proof for next gen consoles.
XG248Q is laggier at 60hz/120hz than the 3 I mentioned, faster at 240hz.
wNchstR
Post by wNchstR » 18 Jul 2019, 13:18
Notty_PT wrote:XG2402, XG240R and LG 24GL600 are your best bets for both console and pc gaming with good future proof for next gen consoles.
Thanks for your answer. I have 2 choices. XG240 and 24GL600F. Which one do you recommend. Because of the stand, I am close to XG240. Which one' performance is better?
Notty_PT
Post by Notty_PT » 18 Jul 2019, 17:00
Get the XG then! Amazing monitor, one of the best ever made
TTT
Post by TTT » 19 Jul 2019, 09:07
Whichever you use make sure the monitor doesn't use a different scaler when you plug in HDMI.
The gsync 240hz screens are like playing on a laggy TV on console with HDMI because of this.
wNchstR
Post by wNchstR » 14 Aug 2019, 14:18
Do you know Asus PG248Q?
60-Hz-Overdrive „Normal“ İnput Lag: 1.2 ms
https://www.prad.de/testberichte/test-m ... -pg248q/6/
TTT
Post by TTT » 17 Sep 2019, 11:03
wNchstR wrote:Do you know Asus PG248Q?
Yea thats not the 240hz one, that is probably fine.
wNchstR
Post by wNchstR » 18 Sep 2019, 16:09
When we look the rates from Prad.de can we say the fastest console monitor for PG248Q ??
TTT
Post by TTT » 19 Sep 2019, 07:28
I don't know I'm not German.
Its a massive waste of money buying that primarily for console though, there are no future proof monitors for console really seeing as nobody knows solid info on the next gen either.
They will be Freesync2 over HDMI though, there still isn't many monitors even with that.
