Wanted to try out RTSS and Scanline sync but can't get it to work. Whenever i activate Scanline sync by entering any value besides 0, the fps instantly locks to my secondary monitors refresh rate. I have a BenQ xl2411z that I wanted to use in games with 100hz and the VT tweak for improved strobing and combine this with Scanline Sync. I've tried to change the refresh rate of my secondary monitor and the fps in-games simply sticks to whatever value this is. '
Anyone got some idea what could be going wrong?
Scanline Sync locks at secondary monitor refresh rate
Re: Scanline Sync locks at secondary monitor refresh rate
Probably a bug -- I've heard of this.
This needs to be reported to Guru3D
To support Blur Busters:
• List of G-SYNC Monitors
• List of FreeSync Monitors
• List of Ultrawide Monitors
Oh too bad, is it a hardware bug or would something like reinstalling windows fix it. I've also tried to only have my main monitor connected but then it wouldn't lock the fps at anything so I suspect that somehow scanline sync doesn't want to work with my Benq monitor.Chief Blur Buster wrote:Probably a bug -- I've heard of this.
I think there is a configuration option you can add/edit in the RTSS profile to tell it the index of the monitor you want to sync to.
Twitter • Steam • GitHub • Stack Overflow
Yeah I've tried to edit that without any luck. It's only a problem with my main monitor (XL2411Z) as my other monitor works fine. If i simply disconnect all other monitors then the fps isn't locket at all.RealNC wrote:I think there is a configuration option you can add/edit in the RTSS profile to tell it the index of the monitor you want to sync to.
