Ultra low latency
GFresha
Ultra low latency
Post by GFresha » 19 Sep 2019, 23:14
Using some bro logic but is it true we are supposed to disable this setting any time any type of game gives us 70%+ of CPU usage?
Also is it really the same as pre rendered frames set at 1 if we just turn it on and not ultra? I don't know I am noticing FPS drops in Greedfall with this setting turned on, some areas giving me 30 FPS!! Might be game flaw as I havent seen this issue somewhere else.
MatrixQW
Re: Ultra low latency
Post by MatrixQW » 20 Sep 2019, 04:12
TTT
Post by TTT » 19 Oct 2019, 04:21
GFresha wrote:Using some bro logic but is it true we are supposed to disable this setting any time any type of game gives us 70%+ of CPU usage?
Read the description in NCP.. Turning it on is 1 max pre rendered frames.
