radeon anti-lag+scanlinesync?
Posted: 07 Oct 2019, 18:23
by mist
Is radeon anti-lag compatible and useful with ScanlineSync or not?
Re: radeon anti-lag+scanlinesync?
Posted: 07 Oct 2019, 23:15
by RealNC
It is compatible since it only affects the prerender queue size. As to how useful it is, not sure. If the GPU gets completely maxed out (which is where anti-lag helps,) you'll have bigger issues to worry about with ssync than input lag. Like severe stutter.
Posted: 12 Oct 2019, 02:50
by HiAlgoBoost
@RealNC - no, that is not correct:
1) "it only affects the prerender queue size" - not true (don't believe everything NV fans say)
2) "GPU maxed out ==> severe stutter" - also not true.
Posted: 12 Oct 2019, 03:56
by Sparky
HiAlgoBoost wrote:@RealNC - no, that is not correct:
1: what else, specifically, do you think it does?
2: this is in the context of scanline sync.
Posted: 17 Oct 2019, 14:37
by HiAlgoBoost
What do you mean “what do I think it does”? I know exactly what it does... ;)
