You all know by now that when you use the superfast mode, you get alot of coronas.
what you can do to fix that, is you can go into the monitors serice menu and lower the "Overdrive Gain" from 40 to something you`re comfortable with.
to enter the service menu, you turn of the monitor then hold these 2 buttons and turn on the monitor.
https://gyazo.com/e022c3d83c686914f3354f0a01179fe9
after you do that, stop holding the 2 buttons and press this one for the menu window to pop up.
https://gyazo.com/fb00da87f37ab6b20b30d3da536dec61
AW2518HF tweak/trick for "Superfast"
Re: AW2518HF tweak/trick for "Superfast"
LE: This resets when you turn off your monitor so you have to do it each time you want to game.
