Help please guys,
game not smooth 144hz
choppy players animations
bad feel spray
weird hitreg
inconstant aim (actually unstable input lag)
monitor benq xl2720z (amd card r9 270x) and intel i7-4770 cpu 3.40Ghz
this is not normal 6 ms, it should be 1 ms
144Hz problem cs go
Re: 144Hz problem cs go
MPRT test is not a lag test. It's a motion blur test. Motion blur isn't the same thing as lag.
Take a photo of www.testufo.com/frameskipping
Let me guess... You have two monitors connected, one of them being your 60Hz monitor?
1. Single monitor mode. UNPLUG your 60Hz monitor.
2. If you want to keep multimonitor, use the 144Hz monitor as primary, and use fullscreen exclusive mode.
Chief Blur Buster wrote: ↑19 Mar 2020, 14:13Take a photo of www.testufo.com/frameskipping
I only have 1 monitor.I have a dvi cable . Do I need to clear all the boxes? and to remove 60 hz ? sorry for the bad english.
This approach is incorrect. It won't help. Do not use CRU.
Your 144Hz is fine in TestUFO.
Also MPRT test is not a lag test. MPRT(100%) is always 6.9ms persistence for a non-strobed 144Hz display.
However, if you only have 1 monitor, then more diagnosis & avoid is required.
-- Do you still get this inconsistent behaviour with bots in offline mode? Play "Offline with Bots".
-- Do you get the same stutters and weird issues
