I'm not surprised. Wires acts as antenna that pick up interference. That's a problem.bijay135 wrote: β16 Jan 2021, 00:09Hello everyone, like all of you I suffer from this problem. I had posted here few months before and chief told me to check a fluorescent tube method to check emi level since I am very near a power line. I did try it it did not light up at all, guess it's not so bad after all.
I tried everything for about 3 years to fix this, was a hardcore cs go player. After 3 years of failure I could no longer keep up at the risk of going insane I sold my pc altogether and bought a ps4, been happy ever since. This issue does not seem to affect wireless input devices at least in my case. I can play online/offline games all day with wireless dual shock 4 and never notice any issues. I also started using wireless keyboard/mouse for general pc use ( I no longer use pc for gaming ). It's been working fine over 2 - 3 years for me.
Since cod warzone had keyboard/mouse support in ps4. I did recently tried my existing wired keyboard/gaming mouse and the problem is still there. After 30 or so minutes the input starts getting massively floaty, feeling like sliding on ice and I can no longer aim properly at all, since inputs are massively delayed. Next day or a fresh gaming session same thing repeats, mouse is only usable for about 30 minutes to an hour. I also bought a brand new gaming mouse just to test, it was completely fine for about 3 days and this issue started again. So, I am back to playing with wireless controller.
I want to try a wireless gaming mouse in future if I can find a budget one, that is only thing left to test for me or move house somewhere else in future and hope this issue is not there. Maybe the wireless solution can work for at least some of you. Thank you for reading and do reply me if you got any questions .
Hmmm.... You may be a perfect test case to test a theory I have. The biggest problem will be unshielded wires, like poorly-shielded mouse cables. They act as antennas in high-voltage transmission corridors.
Find a thick metal tube, and stuff your mouse cable inside it (but not coiled-up, as coiled wire can amplify its ability to pick up interference in this case). See if the mouse stops being laggy. (It will be hard to move the mouse much, but it might change the latency behavior). The problem is the powerful EMI of a power transmission corridor is powerful enough to punch through a lot of shielding, but it might attenuate enough to stop lagging the mouse.
Another test to try is adjust the axis of the mouse cable towards you (near-far), sideways (left-right), and vertical (up-down), this can vary the amount of interference injected into the cable -- much like fiddling with rabbit-ears TV antennas.
A wireless mouse is probably superior for latency in a strong electric field environment (electric field EMI that interferes badly with cables, instead of radiofrequency EMI that interferes badly with wireless signals). In your case, eliminating wires that could act as antennas to pick up strong interference.
The cables of many esports mice are thinly/poorly shielded, because the mouse cable has to be flexible.
I imagine one can modify a gaming mouse to use a coaxially shielded USB cable, so that the gaming mouse works properly in high-EMI environments.
Some YouTuber should set up a gaming desk (with cheap equipment) in the grass underneath 735,000 volt electric transmission line corridor and see what happens -- I imagine there will be some problems with some computer accessories, because unshielded wires are like antennas...
What model of mouse do you have? Some mice have more well-shielded cables than other brands.
Possible Tip For Readers Who Live Near Power Transmission Corridors
Try using wireless keyboards & wireless gaming mice if you live near a high-voltage transmission corridor. Yes, wireless devices is more laggy than cabled devices in a low-EMI environment, but there are cases where wireless can outperform wired in latency when you're stuck near a high voltage power transmission corridor. Choose high-quality gaming-optimized wireless devices, which will at least be less laggy than older wireless devices.
