I want seamless and low input lag in Escape from Tarkov with a 240Hz monitor.
I know that for least input lag but nice image you want GSYNC, VSYNC on in NVCP, 240HZ + -3fps framerate cap in game or if not in NVCP framerate cap, but tarkov only has framerate cap to 120, so i use the NVCP framerate cap to have it higher than that. Now im wondering if i should cap this to 237fps. That will cause my game to change in fps and run gpu at 90-98%. Should i put framerate cap to like 144fps to have more open capacity for gpu to play with? I heard 98% and above is bad for input lag.
Edit: I have a 2070 Super GPU. Is below 90% usage prefered?
ESCAPE FROM TARKOV - 240Hz - INPUT LAG DECREASE
Return to “Input Lag / Display Lag / Network Lag”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
