Hi, I want the least delay, I play cs go. I have asus xg258q and msi geforce 1080gtx +
I'd like to know the best settings for cs go for delay.
1) choose GPU scaling or monitor?
2) I have chosen resolution 1920x1080 240hz but it is not native, should I remove in CRU TV resoultion that my resolution was native ??
3) should I add a resolution of 1280x960 240hz in CRU or nvidia because I play 1280x960 in cs go? or maybye add 1440x1080 to nvidia?
4) set in nvidia settings low latence mode for ultra? or on? off?
5) I get a very blurred text when scrolling. Why?
Problem with asus xg258q
- question 2
- Screenshot - 11_04 002.png (7.39 KiB) Viewed 3067 times
Re: Problem with asus xg258q
1)
This on is tricky. Generally it depends very on much on the monitor, and the GPU. In your case i would personally use the GPU. Seems like also all the pro players use GPU scaling in cs anyways.
4)
You don't need LLM unless your GPU reaches 100 %. https://www.youtube.com/watch?v=7CKnJ5ujL_Q
i dont understand question 2,3 - and i dont have a solution for 5.
4)
2) I have Ultra hd resolution -> 1080p, 1920x1080 60hz, which is native, and at the bottom of the PC resolution 1920x1080 240hz, which is not native
