I have 2 systems:
OLD:
Xeon X3440@4GHz 1.39v
ASUS P7P55D
8+8Gb Samsung PC1600@2100CL12
GeForce GTX1070 8Gb Gigabyte Mini ITX (replaced by GTX 1060 6Gb Palit dual)
FSP 550-80GLN
Benq XL2410T Tn\1080p\120Hz 2011y.
OS: Windows 10 1909
and NEW:
Ryzen 5 [email protected] 1.37v Fixed
MSI X470 gaming pro
16+16Gb Ballistix Sport LT 3000CL15@3600Cl16
GeForce GTX1070 8Gb Gigabyte Mini ITX (same videcard)
Corsair RM750x
Acer Nitro VG270UPbmiipx [UM.HV0EE.P01] IPS\1440p\144Hz 2019y.
OS: Windows 10 1909
I play BF1 and COD: MW at the minimum settings, I feel that the input lag has increased on the new system. Despite the significantly increased FPS, it became harder for me to aim. On one of the YouTube channels, AMD and Intel processors were compared, the processor from AMD had a much larger input lag. (click) Tell me, is this true, or is it already fixed on zen2?
Is it true that AMD Ryzen has a larger input lag?
Re: Is it true that AMD Ryzen has a larger input lag?
No clue, but I appreciate low input latency and 'rawness'.
I recently upgraded my system and I'm impartial to a specific brand, but for various reasons I choose Intel above AMD. I guess mainly for their 'proven' architecture and can kind of expect what to get.
AMD has great multithreading capability and processing throughput, but that's only a part of the picture.
It is also true that it works with CCX and some delay in between them. There's a whole bunch of complex stuff going on there and to obtain max performance you'll want to try and put a whole game on a single CCX for affinity (And preferably the one that already has the kernel running).
But that is simply too tight. Even CSGO yields higher FPS with more than 4 cores (believe it or not) so you'll always have to deal with that 'latency'.
I don't expect an Intel vs Ryzen system to be in the single digit latency real even, but maybe there is some form of 'rawness' that an Intel system can provide vs a Ryzen system.
Also from personal experience with fooling around with interrupt affinities on different cores, seemed to have some effect on that. (instead of letting majority of DPC's be processed on the 1st core where kernel resides), now imagine having to do that on a cpu with two different CCX.
I dont know, its just not ideal if you ask me. But this is all in the very subjective realm and might not even be measurable properly.
LTSC 21H2 Post-install Script
https://github.com/Marctraider/LiveScript-LTSC-21H2
System: MSI Z390 MEG Ace - 2080 Super (300W mod) - 9900K 5GHz Fixed Core (De-lid) - 32GB DDR3-3733-CL18 - Xonar Essence STX II
- BTRY B 529th FA BN
Keep your IF coupled with your Memory speed (1:1 ratio), and don't use SMT
No, it's just happy Ryzen owners that can't wait to switch back to Intel.Is it true that AMD Ryzen has a larger input lag?
I also have a ryzen system ryzen 5 3600 and input lag in csgo is killing me I had a ryzen 5 2600 and it was the same for that too. When I had a gaming intel laptop i7 4720hq there was no input lag at all. But after building a pc late 2018 and I went with ryzen I have been suffering with input lag for almost 2 years.
Doesn't seem like the difference is all that much, I think it's more to do with windows 10 as there's various things that can influence input lag there more noticeably, like the dwm vs you not having the dwm back on windows 7, or an update screwed with something, etc... cause these days with windows 10 you need to configure it more than you used to have with a fresh windows 7 install to get it to work nicely.
Here's a video of the same guy doing input delay comparison again: https://youtu.be/3UhaZ8VT4fU?t=392
worst case scenario it's 1ms slower, avg is about 3ms difference.
Just build new PC Ryzen 5600x, Rtx 3060ti,Asus rog strix B550 f gaming, HyperX Predator 32GB RAM, load new win10, instal CSgo.
In first match i notice that everybody see me before i see them. Start downloading new drivers bios evrything 100 times. No improve.
I was thinking bad CPU so get second ryzen 5600x, with same result, first CPU was dead.
I buy new mobo MPG b550 gaming plus and ryzen 5800x, same crap.
Today a giving up on this AMD hardware.
CPU maybe powerful but for sure not for online gaming like CS GO. I was playing long time on i7 7700 with gf1060 no problem.
I was trapt on AMD claim that they CPU 19% faster and yes they probaly are faster but they reach that speed after you are allready dead in game.
Perhaps a scenario like this exploits weak links in a system e.g. a slow monitor.MegaMelmek wrote: ↑21 Jan 2021, 14:15Just build new PC Ryzen 5600x, Rtx 3060ti,Asus rog strix B550 f gaming, HyperX Predator 32GB RAM, load new win10, instal CSgo.
My monitor is Alienware 240Hz,
internet: optical cable 1Gig up down, latency sometime over 10ms, 0% loss,
when is bad day it take me download CSgo 10,9Gig in 2min 30sec.
So i thin no problem there.
Did you just swap over your drive or did you do an OS reinstall?MegaMelmek wrote: ↑21 Jan 2021, 17:05My monitor is Alienware 240Hz,
List all your tweaks you did.
Also to provide proof of your claim you should make a video of said issue
