I will buy 240hz monitor for competitive gaming like rainbow six siege and csgo
And i think i should choose TN panel becouse 1ms on tn is more better than 1ms on ips
But im sad becouse im still didnt find the fastest 240hz monitor
So i want the less one for input lag and response time please i want the faster one for my fps competitive games
Gpu 2080ti Cpu i7 9th
Please recommend for the faster and the lower input lag and lower response time
Less input lag and less respons time HeLp?!
Re: Less input lag and less respons time HeLp?!
Hp Omen x 25f is pretty much fastest atm
Its faster than benq xl2546 and kd25f?
I'm in the same situation as you. Omen 25x is the fastest right now combining input lag and time responses.
The only reason I'm holding off is because I'm curious to see the testing on the xl2746s/xl2546s if they are as fast without DYAC (that way I could turn on motion blur reduction for some games) and because there isn't a promo where I live.
Please provide a link to a benchmark where KD25F, XL2546, and HP Omen X 25f are tested using the same methodology.
DrUninstall wrote: ↑02 May 2020, 10:20I'm in the same situation as you. Omen 25x is the fastest right now combining input lag and time responses.
So now which is the fast monitor omen 25x or xl2546s?
Im already have xl2546 so if i want to real upgrade which monitor is worth
Thanks
