Glorious GMMK input lag tests?
I've seen some tests on here for other kbs but am wondering if anyone has a GMMK (I'm specifically considering compact or TKL) and has either tested input lag - I know there can actually be a noticeable difference depending on PCB quality, that the G Pro is often lowest latency. But I'd be excited to have hot-swappable switches!
- RedCloudFuneral
Re: Glorious GMMK input lag tests?
I have the GMMK TKL but I don't know how to test latency. If you want to link me a guide I can test it for you. I'm using Kailh Speed Silver switches.
