[240HZ] G-SYNC ON - VSYNC OFF
LLM "ULTRA"
If there are 150 frames on a 240HZ monitor and the GPU 99%, is there no effect?
Should the 240FPS frame be higher?
LLM "ULTRA"
144HZ - 150~180FPS
240HZ - 240~250FPS
GPU 95~99%
[NOT CAP]
ON "1"
ULTRA "JUST IN TIME?"
Is there any difference between the two options?
If the GPU utilization does not reach 99%, is low-latency mode ON and ultra useless?
144HZ - 120FPS INGAME CAP [GPU 50~80%] <--
Practical use frame 70~120
Is there any effect of low-latency mode?
144HZ INGAME 139 FPS - 139CAP - GPU 56%
Low-latency mode [ULTRA] not working?
How to use low latency mode correctly?
Re: How to use low latency mode correctly?
I assume you're talking about Nvidia's low latency mode right?
Well, changing the setting won't actually effect fps, but it does effect latency, though it can introduce other problems like CPU based stuttering because the CPU would have to process the frames right when GPU has finished, and that may cause stutter problems with games that use lots of CPU to begin with, e.g. RTS games with lots of units etc... because the CPU would have to be ripped away from it's other tasks in order to process the frame it just got from the GPU.
Yes. It only useful if your GPU usage is 99%. And you will get less latency if you just lock your FPS at the value where you don't reach 99% GPU usage.blackstorm82 wrote: ↑01 Jun 2020, 20:47If the GPU utilization does not reach 99%, is low-latency mode ON and ultra useless?
Watch this video where the guy clearly demonstrates it that you want to turn it off and just never reach 99% GPU usage:
