85*f ambient / 29.9*C ambient
140mm fan
stress test on ram
>40*c
Idle temps in 85*f ambient / 29.9*C ambient, are around 32*C
the fan can serve to cool the CPU Heatsink, also.
EDIT: Cougar fan. And it's extremely quiet.
Is it true Ryzen has higher input lag than Intel? Is there conclusive data to prove this?
- BTRY B 529th FA BN
Re: Is it true Ryzen has higher input lag than Intel? Is there conclusive data to prove this?
Thank you! I wanted to buy the ASUS Z490-E Strix, bc ASUS was always good for me. Whats wrong with that? Are the Aorus ones better?MaxTendency wrote: ↑11 Aug 2020, 18:05Pretty good processor. KF usually are lower priced and oc better, so check for that one. However in some countries KF maybe more expensive than K , in which case I'd probably go for the cheaper of the 2. Also for 10700k/kf Unify or Aorus Ultra ITX should be fine, you can also go Apex if you really have lots of money to spare.
Shorter traces and 2 dimms, compared to normal 4dimm atx motherboard.
Can u pls provide more info on this? H2H results, maybe?MaxTendency wrote: ↑11 Aug 2020, 16:29
Also if you're going all out on input delay 5700xt might be worth looking into, the general consensus that (non-vega) amd gpus are snappier than nvidia gpus.
Thnx
- RamenRider
This thread is bullshit. 99% of Input Lag comes from Windows Desktop Rendering and DWM.
Twitch:https://www.twitch.tv/ramenrider
Input Lag Guide: viewtopic.php?f=10&t=7168
AMD Input lag guide. https://community.amd.com/message/2958691
Common sense prevailed in the end.
People may have already responded in the course of the topic, but I'm from Brazil and I don't understand much English, making it difficult to understand and read message by message, or watch any video.
I have a Ryzen 7 3700x, 2x8gb 3200mhz and RTX 2070. It means that someone with an Intel processor equivalent to my Ryzen and the same setup, has the most responsive game that I have? How much? Is there any way to improve this on Ryzen to look like Intel? I ask this because I like to play competitively and use a 240Hz monitor for example. Thank you
It depends on your CPU GHz and memory latencies and clocks, you've given your memory clock, but what's your CPU clock speed and what's the memorie's latency speed?Caronizeeee wrote: ↑18 Sep 2020, 00:10People may have already responded in the course of the topic, but I'm from Brazil and I don't understand much English, making it difficult to understand and read message by message, or watch any video.
deama wrote: ↑18 Sep 2020, 05:06It depends on your CPU GHz and memory latencies and clocks, you've given your memory clock, but what's your CPU clock speed and what's the memorie's latency speed?Caronizeeee wrote: ↑18 Sep 2020, 00:10People may have already responded in the course of the topic, but I'm from Brazil and I don't understand much English, making it difficult to understand and read message by message, or watch any video.
My CPU is around 4.25ghz on all cores. The memory teams (I did a light OC) are:
tCL: 16
tRCDWR: 18
tRCDRD: 19
tRP: 19
tRAS: 38
