So basically my question is concerning the lag test, like the one done here:
https://www.youtube.com/watch?v=_Po6Zqjf-Wo
That monitor runs at 60hz, and at the "gamer mode" it lowers lag time down to 21ms.
My question is, if that monitor was running at 120hz instead, would the lag time be reduced further? Down to around 10.5ms?
How much does refresh rate affect lag times?
Re: How much does refresh rate affect lag times?
If it was 21ms, then other than lag caused by vertical refresh rate, it was 21 - 1000 / 60 = 21 - 16.67 = 4.33ms.deama wrote: ↑13 Jun 2020, 14:13So basically my question is concerning the lag test, like the one done here:
So at 120 Hz that monitor would be around 4.33 + 1000 / 120 = 4.33 + 8.33 = 12.66ms.
Yes, your monitor is the biggest input lag bottleneck in your system. So if you can get higher refresh rate monitor, just get it. Get 360 Hz if you can.
Ah thanks.
I actually am thinking about getting an OLED monitor to try, and when I saw the input lag test I was concerned about that, but maybe I can find a 120hz at least OLED, which would be fine for me, especially if I could get it to around 5ms.
360 Hz? I don't think there is any monitor with such refresh rate available on the market yet. I'd surely like to test it!
Main display (TV/PC monitor): LG 42C21LA (4K 120 Hz OLED / WBE panel)
Tested displays: ASUS VG259QM/VG279QM [favourite LCD FPS display] (280 Hz IPS) • Zowie XL2546K/XL2540K/XL2546 (240 Hz TN DyAc) • Dell S3222DGM [favourite LCD display for the best blacks, contrast and panel uniformity] (165 Hz VA) • Dell Alienware AW2521HFLA (240 Hz IPS) • HP Omen X 25f (240 Hz TN) • MSI MAG251RX (240 Hz IPS) • Gigabyte M27Q (170 Hz IPS) • Acer Predator XB273X (240 Hz IPS G-SYNC) • Acer Predator XB271HU (165 Hz IPS G-SYNC) • Acer Nitro XV272UKV (170 Hz IPS) • Acer Nitro XV252QF (390 Hz IPS) • LG 27GN800 (144 Hz IPS) • LG 27GL850 (144 Hz nanoIPS) • LG 27GP850 (180 Hz nanoIPS) • Samsung Odyssey G7 (240 Hz VA)
OS: Windows 11 Pro GPU: Palit GeForce RTX 4090 GameRock OC CPU: AMD Ryzen 7 7800X3D + be quiet! Dark Rock Pro 4 + Arctic MX-6 RAM: 32GB (2x16GB dual channel) DDR5 Kingston Fury Beast Black 6000 MHz CL30 (fully optimized primary and secondary timings by Buildzoid for SK Hynix die on AM5 platform) PSU: Corsair RM1200x SHIFT 1200W (ATX 3.0, PCIe 5.0 12VHPWR 600W) SSD1: Kingston KC3000 1TB NVMe PCIe 4.0 x4 SSD2: Corsair Force MP510 960GB PCIe 3.0 x4 MB: ASUS ROG STRIX X670E-A GAMING WIFI (GPU PCIe 5.0 x16, NVMe PCIe 5.0 x4) CASE: be quiet! Silent Base 802 Window White CASE FANS: be quiet! Silent Wings 4 140mm PWM (3x front, 1x rear, 1x top rear, positive pressure) MOUSE: Logitech G PRO X Superlight (white) Lightspeed wireless MOUSEPAD: ARTISAN FX HIEN (wine red, soft, XL) KEYBOARD: Logitech G915 TKL (white, GL Tactile) Lightspeed wireless HEADPHONES: Sennheiser Momentum 4 Wireless (white) 24-bit 96 KHz + Sennheiser BTD600 Bluetooth 5.2 aptX Adaptive CHAIR: Herman Miller Aeron (graphite, fully loaded, size C)
Oh I forgot to ask, what if the monitor above measured 13ms at 60hz?Kulagin wrote: ↑14 Jun 2020, 05:58If it was 21ms, then other than lag caused by vertical refresh rate, it was 21 - 1000 / 60 = 21 - 16.67 = 4.33ms.deama wrote: ↑13 Jun 2020, 14:13So basically my question is concerning the lag test, like the one done here:
Does that mean it would be 13-1000 / 60 = 13-16.67 = -3.67 ?
So -3.67 - 1000 / 120 = -3.67 + 8.33 = 4.66ms?
