Does Nvidia FREESTYLE add input lag if it doesn't drop my FPS? EDIT: yes it does
Does anyone know if Nvidia Freestyle (the filters you can add in-game) add any input lag, assuming my FPS remain constant? Does anyone have a technical article, or quantitative data? Thanks in advance!
Edit: I messed up the first title, wrote freesync instead of freestyle.
Re: Does Nvidia FREESTYLE add input lag if it doesn't drop my FPS?
If it doesn’t affect your FPS then no. I use it for warzone with no issues.
Hey, thanks for the answer! However, input lag does not merely depend on FPS. For example, I could create a filter that executes very very fast, but requires a few frames to do whatever I want. Push it to the extreme, and consider that my filter requires 1 second worth of frames. It wouldn't affect your FPS, but you would feel a huge delay when gaming.
FPS is a variable in the input delay equation, but doesn't tell the whole story. That's why I was looking for a technical article, or measurement data. For example, it's possible that the filters require the frame to exist already, to then apply post processing on it. This would cause, in the best case scenario, 1 frame of input lag.
As for my subjective opinion, I'm playing Valorant found some simple filters that greatly enhance enemy visibility which translates to faster reaction times when spotting an enemy. However, something feels off when I play with these filters, and I do much better without them on. This might be a placebo effect however, which is why I created this thread
That’s not how post processing works. You either get an FPS impact and minor input lag increase or not.
If anyone is curious, I tested it at my friend's house since he has 2 identical fast TN monitor (xl2540) and the nvidia freestyle filters do add input lag even if it does not cause FPS drops. This explains why my aim felt weird with filters on.
Re: Does Nvidia FREESTYLE add input lag if it doesn't drop my FPS? EDIT: yes it does
I was using the sharpen filter for a short while with Apex but it seemed to affect my performance negatively
I highly doubt this. There’s no technical reason it would unless you lost significant FPS or piled on every single filter there is.nexina7350 wrote: ↑07 Jul 2020, 09:12If anyone is curious, I tested it at my friend's house since he has 2 identical fast TN monitor (xl2540) and the nvidia freestyle filters do add input lag even if it does not cause FPS drops. This explains why my aim felt weird with filters on.
Yes, I feel the same, it's not a huge difference but I can definitely feel the mouse feeling less sharp with filters on while fps remains locked at 144fps.theangryregulator wrote: ↑07 Jul 2020, 09:36I was using the sharpen filter for a short while with Apex but it seemed to affect my performance negatively.
Also, a bit off topic, but I've also tried the new hardware scheduler and my aim is much less consistent in Apex legends(can't wingman) with it on. On kovaaks it's the opposite, a hair snappier and same consistency. Best to leave I off I guess...
We tested with simple filters such as sharpening only, and even the brightness/contrast filter only. According to our tests the amount of input lag does not depend on the quantity nor complexity of filters (as long as FPS don't drop). Still, there was a constant input lag caused by nvidia filters. I believe the other comments in this thread also corroborate this.Dirty Scrubz wrote: ↑07 Jul 2020, 17:55I highly doubt this. There’s no technical reason it would unless you lost significant FPS or piled on every single filter there is.nexina7350 wrote: ↑07 Jul 2020, 09:12If anyone is curious, I tested it at my friend's house since he has 2 identical fast TN monitor (xl2540) and the nvidia freestyle filters do add input lag even if it does not cause FPS drops. This explains why my aim felt weird with filters on.
Tested with what tools and methods? It’s easy to claim you tested something without empirical evidence.
