like i living in block on 3 floors there is 12 floors i mean what can do about that nothingdervu wrote: ↑09 Aug 2020, 05:18I don't have any photos of I/O shield. All I can tell is that you have little prongs on it. One prong that supposed to be touching outer side of USB port was going inbetween USB ports, it looked almost like it went inside. I took it off and cut it out.
One interesting thing is that I found on MSI forums person who a little similiar problem with B450 board, but with intereference in his speakers. He would take off his I/O shield and it magically disappeared, turns out it was onboard audio causing weird things. He went for USB DAC, leaving I/O shield in place. I have USB DAC too, onboard audio turned off.
I am still wondering if the thing I had (I/O shield) could cause some damage that would result in weirdly working system.
Since I bought my PC I had problems with RAM beeps from time to time and it turned out RAM to be faulty (shop said it was very common with this models) and then I got new RAM and had it stick to 1.4V instead of 1.36V to keep it stable on 3200MHz.
@Unixko If it is repeating as you say, every day at same hours, I would say it is something out of your control.
Check this thread https://www.overclock.net/forum/375-mic ... -loss.html
There are people who went so far to get to know that it can be neighborhood problem rather than apartment problem.
Input lag and eSport. Every gamer should know this.
Re: Input lag and eSport. Every gamer should know this.
How many ferrite cores did you add to your mouse wire? Just one? Also, at what positions?dendu wrote: ↑08 Aug 2020, 20:51I have the good mouse feeling from adding ferrite ring cores to the mouse and ethernet cables. Definitely worth trying out, you can sometimes find clip-on rings from old power supply bricks and chargers. Not sure if it lowers input lag, but it has a noticeable effect on mouse control/floatiness for me.deama wrote: ↑07 Aug 2020, 07:53Have there been noticeable improvements from using a UPS and ferrite rings or is it just speculation?Ekwalipt wrote: ↑05 Aug 2020, 23:37There are no official decisions yet. On Russlan-language and foreign forums write that the input lag can be reduced to a minimum with the purchase of a high-quality UPS, installation of manual ferrite rings on the wires, shielding the wires, changing the apartment.
Try looping the mouse cable like in the image and adjusting the size and placement of the loop.
On my setup, the looped ferrite ring is velcro strapped to the built-in ferrite ring of the monitor cable, which is about 10cm from the usb plug end and the loop is about 5cm in diameter and hanging vertically down, also instead of an additional smaller ferrite ring on the end of the mouse cable, one is placed on the looped portion.
Have to experiment a bit, at least you don't need to keep rebooting to test changes (in-game ideally). I came across the ferrite core suggestion from another post on this board and want to say thanks to all for sharing the good info!
It would be interesting if you could do a mouse polling rate graph test with and without the ferrite cores, like this one:
Here's the link to the software
https://www.overclock.net/forum/375-mic ... oaded.html
When you run it highlight it, and then press F2 after you start moving the mouse in a circular motion, make sure you're moving on the desktop and you're not touching the shortcut icons or anything else as this may effect results. Move the mouse for like 5 seconds and then press F2 again to stop it. Then just press Plot and at the bottom left of the new window highlight plot type an pick frequency vs time, that will give you the polling rate graph.
Ferrite Core Setup
No Ferrite Cores
With Ferrite Cores
I collected many logs to get the time scale similar on both graphs. At first it looked like a pattern(smoothness) was emerging, but nope, after enough logging there is no difference really with ferrite cores on or off according to MouseTester.
However, in-game (CSGO), without the ferrite cores, my mouse movement constantly overshoots, swinging back and forth pass the target. I am used to having the ferrite cores on, so I guess I am over compensating in aim and the ferrite cores have a dampening effect, lowering the floatiness and making the crosshair more controllable on my setup.
No Ferrite Cores
With Ferrite Cores
where everywhere is your ferrite cores i am confusedendu wrote: ↑09 Aug 2020, 23:48Ferrite Core Setup
No Ferrite Cores
With Ferrite Cores
Ferrite cores are those bulging cylinder things on the cables.
Actually Ferrite bead is the right term:
https://en.wikipedia.org/wiki/Ferrite_bead
They are worth a try and do help in-game if you sense that software settings/tweaking alone are not having as much effect on improving mouse movement.
I tried placing the ferrite beads in different spots, even inside the mouse and midway along the cable, both positions made movement worse for me. It is sort of related to the elusive power/emi issues that are affecting some. Please try them and share your findings.
Also, maybe before extreme measures like changing apartments, try rearranging your physical computer setup, place the case in a new orientation and try to route the cables so they don't touch each other and keep the power cables away from device ones.
In ideal environment (good electricity, low EMI) even with unstable polling rate you could still have better input-lag and/or mouse movement than somebody with very stable polling rate but bad environment.
Your science problem is you're probably not testing under the same RFI environment.Unixko wrote: ↑10 Aug 2020, 15:15I collected many logs to get the time scale similar on both graphs. At first it looked like a pattern(smoothness) was emerging, but nope, after enough logging there is no difference really with ferrite cores on or off according to MouseTester.
MouseTester app alone, creates a PC that consumes only 60-100 watts (idling computer with power management)
CS:GO creates a PC that consumes >300 watts (GPU chugging at max power) on a typical modern powerful GPU.
The fields of RFI at 300 watts is much bigger and stronger.
TL;DR: You ideally want to rev your computer to maximum (CPU 100%, GPU 100%, Robust Network Througput, AND Robust Disk Throughput) during RFI testing
Re-test MouseTester under the same RFI conditions (GPU generating 3D at full power). The problem is multitasking MouseTester and CS:GO may not be possible. Maybe primary-monitor CS:GO with secondary-monitor MouseTester? You may have to launch into some disposable super-frantic CS:GO server with a disposable account, so you don't ruin your CS:GO as a sitting duck when Alt+Tabbing to MouseTester. Even that might not work, if the game internally pauses some processing when Alt-Tabbed. Make sure to use VSYNC OFF though, to full-throttle your GPU RFI / CPU RFI to the maximum interference possible. Keep the network spewing hard (maximum network RFI), so be in an online game while running MouseTester.
To understand better, you literally want as many as possible -- transistors and cables and circuit paths -- hot with signals simultaneously, churning those pixels, bytes, polygons, game data, movements, packets, whatnot, etc. Blast the packets, blast the frames, blast the polls, get the GPU 100% CPU 100%... If one of your chips or cables are idle, de-idle it somehow, when running RFI-rejection performance tests. Create the duress condition.
Don't forget to add a Kill-a-Watt to your lab testing equipment if you're an aspiring hardware tester who wants to scientifically reproduce RFI testing conditions. A computer is not a polar Yes/No in RFI behavior. You have to really chug-chug the maximum number of copper wires & transistors possible, to intentionally maximize RFI problems, which means.... Full hardcore network GAMING while mouse-testing.
For RFI testing, redline your computer to the max! Sometimes RFI only shows up at the figurative metaphorical redline region, on the metaphorical RPM meter of your computer. Get all the chips and wires as hot as possible simultaneously. This is where scientific testing of ferrite cores starts to show actual results.
Sherlock Holming the science, baby!
P.S.
MouseTester is open source. Are you a software developer? One could modify MouseTester to use mousehooks (HOOKPROC LowLevelMouseProc via SetWIndowsHookEx), so that you can run it on a secondary monitor while playing the game on a primary monitor (at least on cheat-allowed servers, since mouse hooks are detected by anticheat software). This would make RFI testing easier with MouseTester
