https://www.youtube.com/watch?v=-cXg7GQogAE
https://www.nvidia.com/en-us/geforce/ne ... -platform/
NVIDIA Reflex SDK: A new set of APIs for game developers to reduce and measure rendering latency. By integrating directly with the game, Reflex Low Latency Mode aligns game engine work to complete just-in-time for rendering, eliminating the GPU render queue and reducing CPU back pressure in GPU intensive scenes. This delivers latency reductions above and beyond existing driver-only techniques, such as NVIDIA Ultra Low Latency Mode.
“NVIDIA Reflex technology arms developers with new features to minimize latency in their games. We’re seeing excellent responsiveness and player control with Fortnite running on the GeForce RTX 30 Series.” - Nick Penwarden, VP of Engineering, Epic Games.
“Valorant was designed from the beginning to be a precise, competitive FPS, and that means doing everything we can to ensure crisp, responsive gameplay. With GeForce RTX 30 Series and NVIDIA Reflex technology, we're able to serve players around the world with the lowest render latency possible.” - Dave Heironymus, Director of Technology - Valorant / Riot Games
NVIDIA Reflex will deliver latency improvements in GPU-intensive gaming scenarios on GeForce GTX 900 and higher NVIDIA graphics cards in top competitive games, including Fortnite, Valorant, Apex Legends, Call of Duty: Black Ops Cold War, Call of Duty: Modern Warfare, Call of Duty: Warzone, and Destiny 2.
With popular mid-range cards, like the GeForce GTX 1660 Super, gamers can expect up to a 33% improvement in PC responsiveness with Reflex. Add in a GeForce RTX 3080 and a 360Hz G-SYNC esports display, and gamers can play like the pros with the very lowest latency possible.
PS: Being able to measure your latency through your monitor sounds pretty slick.
Nvidia Reflex
Re: Nvidia Reflex
Honestly this release from NVidia is impressive. The software stack seems to improve and encompass more things while AMD seems stuck.
At this rate I'll probably get an Nvidia card for my next upgrade again.
Re: Nvidia Reflex
So will this be something you can enable for games like ultra low latency or will it be something the devs can use to help reduce input lag?
Re: Nvidia Reflex
Pretty sure the game devs have to add it, I think it's functionally equivalent to using an in-game framerate cap, at least in terms of the mechanism by which it reduces latency. So instead of whatever timer you call to implement the framerate cap, you call nvidia's new thingy, and it adds enough of a delay you don't fill the buffers. Presumably it adjusts the delay to keep the GPU close to full load instead of at a fixed framerate like a normal framerate cap.
I'm somewhat curious how much this will cut the latency of normal v-sync.
Not sure about the latency measurement tools. It should be effective for comparing different games and settings, but I don't trust it for mouse or monitor latency.
Re: Nvidia Reflex
I'm in the "wait and see" group myself. Lots of unknowns, but potentially revolutionary, at least where user-accessible input lag measurements are concerned. "Potentially" being the key word . Execution, accuracy, and its availability across games would be key there.
As for a possibly more consistent or automatic elimination of the pre-rendered frames queue (via something effectively like an adaptive FPS limit/frametime target based on the current GPU usage maybe?), honestly a little less impressive (since it is already basically achievable with fixed FPS caps, as Sparky pointed out), but welcome nonetheless.
Re: Nvidia Reflex
Honestly, so long as nvidia implements it well, they have enough information to get ms accurate measurement of latency. It will need to be independently verified of course, but they have all the information to be able to display accurate frame times.
Anyway, proof is in the pudding for how much latency it cuts down. Any improvement is good.
Re: Nvidia Reflex
I doubt it will do much, but it might be useful for people who can't or just don't want to disable stuff like the dwm, or optimize their setup.
Re: Nvidia Reflex
deama you and your dwm huge killer xD
nobody disable this shit on W10 nobody cares about that for some reason you belive in dmw like is god water
Re: Nvidia Reflex
It's 10 extra ms of input lag that could relatively easily be disabled, and that's on a 120hz monitor, it's extra 16-18ms if on a 60hz.
Nvidia probably could write something to bypass that or force dwm off when playing a game, without having to deal with either disabling dwm yourself completely, or trying to make games work in fullscreen exclusive mode.
Re: Nvidia Reflex
deama
2-3 games in which input lag is important and which cannot work in efs. not worth it every time you mention: the need to disable dwm. I think that's exactly what Unixko wanted to say.
