Everything about latency. Tips, testing methods, mouse lag, display lag, game engine lag, network lag, whole input lag chain, VSYNC OFF vs VSYNC ON, and more!
Input Lag Articles on Blur Busters.
speancer
Post
by speancer » 04 Oct 2020, 10:18
jorimt wrote: ↑28 Sep 2020, 07:34
If you're system isn't GPU-bound, the only thing LLM
might theoretically do is affect frame pacing, depending on how the given engine handles the the pre-rendered frames queue, and if it allows LLM override to take effect (a LOT of games don't, and DX12/Vulkan games don't at all).
LLM "On" is typically safe to leave enabled on a gaming-capable system, GPU-bound or no.
Battle(non)sense found LLM "Ultra" slightly increased input lag in non-GPU-bound scenarios. I haven't tested that myself, so I can only guess why he found that to be the case, said guess being it caused repeat frames here and there due to its "just-in-time" delivery component acting up when the system wasn't GPU-bound, but that's up in the air.
Anyway, as I've said elsewhere, LLM is a highly overvalued setting. Even at its best, it doesn't do much to reduce input lag; typically around 1 to a little over 1 frame reduction in GPU-bound scenarios.
Thank you for clearing this matter up even further (as I asked about it before already). I keep LLM "On" for CS:GO, just for a peace of mind. And in the subject of input lag, I guess the most effective way to reduce latency even further in CS:GO would be upgrading my CPU (maybe to i7 9700K/10700K or new Ryzen 5000 series incoming?) and getting 360 Hz display (waiting for PG259QN release!) would it not? I don't think this game would benefit much from a better GPU, so upgrading to a powerful single-core performance CPU is probably the best option. I wonder how much of a difference I'd get upgrading i7 4790K @ 4.7 GHz to something like i7 10700K @ 5.0~ GHz... Most of the test I find don't really make this clear for me, as I stick to low options and low resolution, but some differences between the newer CPUs are so small that it makes the pricing gaps ridicolous (from a solely gaming-wise point of view). I imagine there could be significant improvement with 10th gen Intel over old boy like 4790K
disq wrote: ↑29 Sep 2020, 15:28
that's what i was thinking, thanks for your input @jorimt
and sorry @speancer for the slightly thread hijack
It's ok, I don't mind at all
Tested displays: Zowie XL2546K • ASUS VG259QM • ASUS VG279QM • Omen X 25f • Zowie XL2546 • MSI MAG251RX • Acer Predator XB273 X • Acer Predator XB271HU
Displays to test: ASUS VG258QM • Zowie XL2540K (currently testing)
Post
by jorimt » 04 Oct 2020, 11:55
speancer wrote: ↑04 Oct 2020, 10:18
Yes, for CS:GO, you want the highest single-threaded CPU performance possible, and the highest refresh rate possible (decreased scanout time) to take advantage of the higher framerates in non-GPU-bound scenarios.
As for a CPU upgrade, just look for the CPU that provides the highest increase in single-threaded performance over your previous CPU while balancing cost/core-count/overall performance ratio.
Displays: Acer Predator XB271HU / LG 48CX OS: Windows 10 MB: ASUS ROG Maximus X Hero CPU: i7-8700k GPU: EVGA RTX 3080 FTW3 UG RAM: 32GB G.SKILL TridentZ @3200MHz
