Page 1 of 3
NVIDIA Low Latency Mode question
Posted: 28 Sep 2020, 05:33
by speancer
Does enabling Low Latency Mode in NVIDIA Control Panel (either "on" or "ultra") do anything at all in terms of input lag reduction if you play a game at very high frame rate (200+ at all times) that is not GPU-bound at all (e.g. CS:GO) ? Is there any negative performance impact coming from enabling this option in high frame rate non GPU-bound scenario?
Re: NVIDIA Low Latency Mode question
Posted: 28 Sep 2020, 07:34
by jorimt
If you're system isn't GPU-bound, the only thing LLM
might theoretically do is affect frame pacing, depending on how the given engine handles the the pre-rendered frames queue, and if it allows LLM override to take effect (a LOT of games don't, and DX12/Vulkan games don't at all).
LLM "On" is typically safe to leave enabled on a gaming-capable system, GPU-bound or no.
Battle(non)sense found LLM "Ultra" slightly increased input lag in non-GPU-bound scenarios. I haven't tested that myself, so I can only guess why he found that to be the case, said guess being it caused repeat frames here and there due to its "just-in-time" delivery component acting up when the system wasn't GPU-bound, but that's up in the air.
Anyway, as I've said elsewhere, LLM is a highly overvalued setting. Even at its best, it doesn't do much to reduce input lag; typically around 1 to a little over 1 frame reduction in GPU-bound scenarios.
Posted: 28 Sep 2020, 13:13
by MatrixQW
jorimt wrote: ↑28 Sep 2020, 07:34
What does/do you mean by frame pacing?
Detrimental or beneficial?
Posted: 28 Sep 2020, 14:37
by jorimt
MatrixQW wrote: ↑28 Sep 2020, 13:13
In non-GPU-bound scenarios LLM "On" potentially neutral/beneficial, LLM "Ultra" potentially neutral/detrimental.
Posted: 28 Sep 2020, 22:51
by disq
btw and sorry to (kinda) hijack the thread
when a game reaches 95%+ of GPU usage for a couple of frames, like this:
would this be considered "GPU bound"? and so the need to use LLM?
Posted: 29 Sep 2020, 10:07
by jorimt
disq wrote: ↑28 Sep 2020, 22:51
Unless you've closely monitored each game, determined your minimum achievable framerate, and set the FPS limiter to that, the likelihood is, in many games, unless said games are heavily CPU-dependent (e.g. CS:GO), your system is going to drop in and out of GPU-bound scenarios at any given time depending on the demands of the given scene.
This is why I typically recommend keeping LLM "On" (with or without G-SYNC), so IF your system becomes GPU-bound at any point, and IF the game in question supports LLM override, you'll potentially keep the pre-rendered frames queue lower.
I personally just keep LLM globally set to "On," since at worst, it does nothing, and at best, you could reduce input lag by about 1 frame in GPU-bound scenarios.
Posted: 29 Sep 2020, 12:11
by disq
Forgot to mention that i already capped my frames, and i'm only talking about one game, which i locked at 120fps (with GSYNC) but as you can see above, it still goes to 95%+ GPU Usage in some frames
My confusion comes from Battle(non)sense video (
https://youtu.be/Gub1bI12ODY?t=277) where in the smooth case he keeps LLM off with a cap
I guess that in my case 120fps is still too much and i need to lower it more to avoid those tiny spikes to 95% or above in few frames?!
Posted: 29 Sep 2020, 12:32
by jorimt
disq wrote: ↑29 Sep 2020, 12:11
< 95% can still be in the "safe" range, but yes, if you want to ensure your system is never GPU-bound in that game, you'll need to lower your cap to more closely match your 1% lows, for instance.
Posted: 29 Sep 2020, 15:28
by disq
that's what i was thinking, thanks for your input @jorimt
and sorry @speancer for the slightly thread hijack
Posted: 29 Sep 2020, 16:01
by jorimt
disq wrote: ↑29 Sep 2020, 15:28
No worries @disq, and it was still within subject
