Post
by speancer » 04 Oct 2020, 10:18
jorimt wrote: ↑28 Sep 2020, 07:34
If you're system isn't GPU-bound, the only thing LLM
might theoretically do is affect frame pacing, depending on how the given engine handles the the pre-rendered frames queue, and if it allows LLM override to take effect (a LOT of games don't, and DX12/Vulkan games don't at all).
LLM "On" is typically safe to leave enabled on a gaming-capable system, GPU-bound or no.
Battle(non)sense found LLM "Ultra" slightly increased input lag in non-GPU-bound scenarios. I haven't tested that myself, so I can only guess why he found that to be the case, said guess being it caused repeat frames here and there due to its "just-in-time" delivery component acting up when the system wasn't GPU-bound, but that's up in the air.
Anyway, as I've said elsewhere, LLM is a highly overvalued setting. Even at its best, it doesn't do much to reduce input lag; typically around 1 to a little over 1 frame reduction in GPU-bound scenarios.
Thank you for clearing this matter up even further (as I asked about it before already). I keep LLM "On" for CS:GO, just for a peace of mind. And in the subject of input lag, I guess the most effective way to reduce latency even further in CS:GO would be upgrading my CPU (maybe to i7 9700K/10700K or new Ryzen 5000 series incoming?) and getting 360 Hz display (waiting for PG259QN release!) would it not? I don't think this game would benefit much from a better GPU, so upgrading to a powerful single-core performance CPU is probably the best option. I wonder how much of a difference I'd get upgrading i7 4790K @ 4.7 GHz to something like i7 10700K @ 5.0~ GHz... Most of the test I find don't really make this clear for me, as I stick to low options and low resolution, but some differences between the newer CPUs are so small that it makes the pricing gaps ridicolous (from a solely gaming-wise point of view). I imagine there could be significant improvement with 10th gen Intel over old boy like 4790K
disq wrote: ↑29 Sep 2020, 15:28
that's what i was thinking, thanks for your input @jorimt
and sorry @speancer for the slightly thread hijack
It's ok, I don't mind at all
Main display (TV/PC monitor): LG 42C21LA (4K 120 Hz OLED / WBE panel)
Tested displays: ASUS VG259QM/VG279QM [favourite LCD FPS display] (280 Hz IPS) • Zowie XL2546K/XL2540K/XL2546 (240 Hz TN DyAc) • Dell S3222DGM [favourite LCD display for the best blacks, contrast and panel uniformity] (165 Hz VA) • Dell Alienware AW2521HFLA (240 Hz IPS) • HP Omen X 25f (240 Hz TN) • MSI MAG251RX (240 Hz IPS) • Gigabyte M27Q (170 Hz IPS) • Acer Predator XB273X (240 Hz IPS G-SYNC) • Acer Predator XB271HU (165 Hz IPS G-SYNC) • Acer Nitro XV272UKV (170 Hz IPS) • Acer Nitro XV252QF (390 Hz IPS) • LG 27GN800 (144 Hz IPS) • LG 27GL850 (144 Hz nanoIPS) • LG 27GP850 (180 Hz nanoIPS) • Samsung Odyssey G7 (240 Hz VA)
OS: Windows 11 Pro GPU: Palit GeForce RTX 4090 GameRock OC CPU: AMD Ryzen 7 7800X3D + be quiet! Dark Rock Pro 4 + Arctic MX-6 RAM: 32GB (2x16GB dual channel) DDR5 Kingston Fury Beast Black 6000 MHz CL30 (fully optimized primary and secondary timings by Buildzoid for SK Hynix die on AM5 platform) PSU: Corsair RM1200x SHIFT 1200W (ATX 3.0, PCIe 5.0 12VHPWR 600W) SSD1: Kingston KC3000 1TB NVMe PCIe 4.0 x4 SSD2: Corsair Force MP510 960GB PCIe 3.0 x4 MB: ASUS ROG STRIX X670E-A GAMING WIFI (GPU PCIe 5.0 x16, NVMe PCIe 5.0 x4) CASE: be quiet! Silent Base 802 Window White CASE FANS: be quiet! Silent Wings 4 140mm PWM (3x front, 1x rear, 1x top rear, positive pressure) MOUSE: Logitech G PRO X Superlight (white) Lightspeed wireless MOUSEPAD: ARTISAN FX HIEN (wine red, soft, XL) KEYBOARD: Logitech G915 TKL (white, GL Tactile) Lightspeed wireless HEADPHONES: Sennheiser Momentum 4 Wireless (white) 24-bit 96 KHz + Sennheiser BTD600 Bluetooth 5.2 aptX Adaptive CHAIR: Herman Miller Aeron (graphite, fully loaded, size C)
