I would like that I could like small sized shoebox fps shooter games with high fps, so I could enjoy it even better.
Boanerges wrote: ↑02 Feb 2021, 00:21A question for the Chief. I notice that Razer suggest turning off G-Sync, FreeSync etc when using the Viper 8KHz at 8000Hz. Any thoughts or observations regarding this, particularly with the emphasis on G-Sync etc on Blur Busters. Did you (the Chief) try G-Sync on/off when testing the prototype. I've ordered a Viper 8KHz but as it hasn't arrived yet I haven't tested this.
-KaldaienG-Sync has performance issues with mice if their polling rate is too high. You get profound stuttering w/ G-Sync if you poll the mouse at >= 500 Hz in many graphics engines.
The problem has to do with games that use the hardware cursor. If that is drawn in G-Sync, and you move the mouse rapidly, your performance is going to go to hell in a handbasket.
If you can make sure the game never draws a mouse cursor, then it’s safe to use high polling rate with G-Sync. Otherwise, it’s going to cause problems.
Browser based tools aren't fast enough to accurately capture mouse reports that fast. You'll need to use a local application.hkngo007 wrote: ↑03 Feb 2021, 19:09Hello,
I just received my viper 8khz.
It's configured at 8Khz but on testing sites such as:
https://mouseinsider.com/mouse-polling-rate-checker/
I get max 5.6Khz and average 5Khz (doing circles).
https://zowie.benq.com/zh-tw/support/mo ... ecker.html
I get average 5Khz (doing circles).
Is this expected or normal??? Not sure how to check what it is running at in games? Any suggestions?
i will reference on that because previously i already mentioned/observed that conventional 1khz mice easily caps to 1khz in the dynamic scaling nature at relatively moderate speed, however, the same speed now yields at least 2k-4k. maybe even 5k. that alone means up to 5x more agility on the average motion, and of course it can go even higher. it doesn't really go above 7500hz (that is, per your own in house tool which ironically doesn't even refresh fast, it's 1hz, meaning if it didn't average things out it skipped 7999/8000 data points in full spec) for your average wrist aimer, and for involving arm movement it goes to 7600-7800. that is of course likely to vary for different setups. It would be more informational to update this tool to at least like 5-10hz or something.Razer_TheFiend wrote: ↑03 Feb 2021, 23:13Browser based tools aren't fast enough to accurately capture mouse reports that fast. You'll need to use a local application.hkngo007 wrote: ↑03 Feb 2021, 19:09Hello,
We made our internal polling rate test tool available to the public here : https://rzr.to/pollingrate
Or you can also try mousetester, if you prefer a third-party tool : https://github.com/microe1/MouseTester
Our tool is actually doing it correct and by the book - showing the number of reports in the past 1 second - which is exactly how mouse "Hz" is defined (reports per second).lyrill wrote: ↑04 Feb 2021, 01:25i will reference on that because previously i already mentioned/observed that conventional 1khz mice easily caps to 1khz in the dynamic scaling nature at relatively moderate speed, however, the same speed now yields at least 2k-4k. maybe even 5k. that alone means up to 5x more agility on the average motion, and of course it can go even higher. it doesn't really go above 7500hz (that is, per your own in house tool which ironically doesn't even refresh fast, it's 1hz, meaning if it didn't average things out it skipped 7999/8000 data points in full spec) for your average wrist aimer, and for involving arm movement it goes to 7600-7800. that is of course likely to vary for different setups. It would be more informational to update this tool to at least like 5-10hz or something.Razer_TheFiend wrote: ↑03 Feb 2021, 23:13Browser based tools aren't fast enough to accurately capture mouse reports that fast. You'll need to use a local application.hkngo007 wrote: ↑03 Feb 2021, 19:09Hello,
