I can't see those on my nvidia inspector, I got driver version 442.50.pox02 wrote: ↑15 Nov 2020, 20:42if u want really low input lag for overwatch try my settings
why set refresh rate to ff0? its hidden feature that nvidia missing its called low-Latency REFRESH_RATE_OVERRIDE_LOW_LATENCY_RR_MASK
u can check here https://docs.nvidia.com/gameworks/conte ... gs_8h.html
DISALLOWED is the lowest input lag flip is good to but if u want hit ur shots over smoothing try it
now the real settings that give u snappy mouse movement
MAX_PENDING_CMD_BUFFERS to 0x1 remove the stutters/lag
MCFORCEHOSTSTAGINGBUFFERSIZE this is really fun u can check it over 1000 but recommending not go above 20 set it 0x00000001 for extreme mouse input lagless
enjoy the fastest mouse input in ow
one more thing i forgot to say to u make sure low latency is off cause disallowed work best with off
HUGE Fix at Input Lag!!!!
Re: HUGE Fix at Input Lag!!!!
i was only able to find the frame rate limiter / max frame rate settings. the rest of the stuff you posted doesn't show up in latest driver under global even with the expanded "unrecognized" list.
https://imgur.com/a/MLU6y17 ¯\_(ツ)_/¯
Are you sure that you do use proper version of nvidiaProfileInspector? https://github.com/Orbmu2k/nvidiaProfil ... g/2.3.0.12
Yeah tank you man <3 I mean if you dont have any idea that these NVIDIA Control panel 3D-Settings would have that much impact (which i didnt know), than its a huge difference and btw i tried out VSYNC off, and it was even better, ^^ Ty'all for responsesChief Blur Buster wrote: ↑16 Nov 2020, 17:06Correct. In all likelihood, the OP was running VSYNC ON.jorimt wrote: ↑15 Nov 2020, 17:55If the OP was previously running uncapped V-SYNC off, Fast Sync would indeed increase input lag, but if the OP was instead running uncap V-SYNC, Fast Sync would reduce input lag by at least two frames (assuming non-GPU-bound situation).
Hard to say though, since the OP didn't specify.
Fast Sync is indeed much lower lag than VSYNC ON.
That said, capped VRR is even lower-lag than Fast Sync.
If you hate VSYNC OFF, then I recommend capped VRR where possible. And where that fails, one of the low-lag VSYNC methods such as RTSS Scanline Sync. There are a large number of low-latency tricks for those who don't want to see VSYNC OFF tearing.
However -- not to disappoint the OP; let the OP savour and enjoy this moment. It is always a pleasant discovery to discover something that really improve latency, even if it is well known to some of us. Some of us just hate VSYNC OFF for one reason or another (some of us are unusually extra-sensitive to tearing, etc). Don't let it bother you (the realization that this isn't a new tweak ) -- I wholeheartedly welcome to the world of low latency tweaking!
Regards,
Ancharizz
Well im curious, how can u apply these settings? (I didnt find out how)Simon95 wrote: ↑16 Nov 2020, 02:22how can i unlock these settings?pox02 wrote: ↑15 Nov 2020, 20:42if u want really low input lag for overwatch try my settings
Edit: Found it thx
Ty for answers,
Regards,
Ancharizz
Well i have to admit after playing few hours, those modifications in nvidiainspector made a significant difference !!
